运动控制
回帖:1个,阅读:1981次 [上一页] [1] [下一页]
MACH2 CNC控制软件
1007
hyh450
文章数:2
历史总积分:1007
发表于:2005/10/27 11:06:00
有谁用过MACH2 CNC控制软件吗? 该软件还可以吗?
1004
CNCQuest
文章数:1
历史总积分:1004
发表于:2005/12/17 21:27:00
以下是引用hyh450在2005-10-27 11:06:00的发言:
The Mach2 CNC software controller is a very good one.
Do you have the registration code
I can read and write Chinese but can''t input in computer.
Feel free to get in touch with me if you want to discuss DIY CNC.
Thanks.
Email: pharmapack@skydsl.com.ph
[此贴子已经被作者于2005-12-18 15:25:49编辑过]
46.8003
