运动控制
回帖:2个,阅读:781次 [上一页] [1] [下一页]
629
运动控制小正
文章数:364
年度积分:629
历史总积分:629
发表于:2023/11/3 9:27:20
本文将使用运动控制器实现与松下A编码器进行数据读取操作。
'************************绝对值编码器部分******************************
SETCOM(38400,8,1,0,1,0) '设置 485 口 PORT1 为自定义协议
GLOBAL DIM tempchar '接收的一个字节
GLOBAL DIM neqbuff(2) '发送识别码 485 为 81H,05H
neqbuff(0) = $81
neqbuff(1) = $05
GLOBAL DIM eotbuff(2) '接收识别码 485 为 80H,04H
eotbuff(0) = $80
eotbuff(1) = $04
GLOBAL DIM ackbuff '接收应答 06H
ackbuff = $06
GLOBAL DIM cmdbuff(20) '发送命令数组
GLOBAL DIM getbuff(20) '接收的字符串
GLOBAL DIM getnum '接收的字节数
getnum = 0
GLOBAL DIM highdata '编码器多圈数据
GLOBAL DIM lowdata '单圈数据
runtask 4,get_char '启动接收字符串任务
MODBUS_REG(0)=0
WHILE 1
 IF MODBUS_REG(0)=1 THEN '判断是否接收到了数据
    MODBUS_REG(0)=0
    getmpos(1,45) '读取站号 1 的多圈与单圈值。
 ENDIF
WEND
END
'读坐标
GLOBAL SUB getmpos(sifunum,rcr) '读伺服编号为 1 的电机的绝对值位置
  cmdbuff(0) = $00
  cmdbuff(1) = sifunum
  cmdbuff(2) = $d2
  cmdbuff(3) = rcr
  neqbuff(0) = $80 + sifunum
  neqbuff(1) = $05
  eotbuff(0) = $80
  eotbuff(1) = $04
  getnum = 0
  putchar #1,neqbuff
  TICKS = 2000 '延时
  WAIT UNTIL (getnum = 2) OR TICKS < 0
  IF getnum = 2 THEN '如果接到了 2 个字符
     IF(getbuff(0)=$80+sifunum) AND (getbuff(1)=$04) THEN'收到应答发送命令
        getnum = 0
        PUTCHAR #1,cmdbuff '发送读取编码器命令
        TICKS = 2000
        WAIT UNTIL (getnum = 3) OR TICKS < 0
        IF(getbuff(0) = $06) AND (getbuff(1) = $80) AND (getbuff(2) = $05) THEN'收到发送请求,给应答
            getnum = 0
            PUTCHAR #1,eotbuff '发送应答,等待接收数据
            TICKS = 2000
            WAIT UNTIL (getnum = 15) OR TICKS < 0
            IF getnum = 15 THEN '读到数据 11-10 为多圈数据 9-7 为单圈数据
               PUTCHAR #1,ackbuff
               highdata = getbuff(11) * $100 + getbuff(10)
               lowdata = getbuff(9) * $10000 + getbuff(8) * $100 +getbuff(7)
               PRINT getbuff(11),getbuff(10),getbuff(9),getbuff(8),getbuff(7),getnum
            ELSE
               PRINT getnum,getbuff(0) ,getbuff(1),"超时重新读取 1"
            ENDIF
          ELSE
           PRINT getbuff(0) ,getbuff(1),"超时重新读取 2"
         ENDIF
       ELSE
         PRINT getbuff(0) ,getbuff(1),"驱动器无应答"
       ENDIF
     ELSE
       PRINT "驱动器无应答"
     ENDIF
END SUB
'串口接收
GLOBAL SUB get_char()
  WHILE 1
     GET #1,tempchar
     getbuff(getnum) = tempchar
     getnum = getnum + 1
  WEND
END SUB
[此贴子已经被jint于2023/11/3 10:03:23编辑过]
629
运动控制小正
文章数:364
年度积分:629
历史总积分:629
发表于:2023/11/3 9:28:56
此楼内容不符合板块规定,不予显示! 查看原帖内容>>
629
运动控制小正
文章数:364
年度积分:629
历史总积分:629
发表于:2023/11/3 9:31:30
31.2002
