运动控制
回帖:2个,阅读:1484次 [上一页] [1] [下一页]
文章数:9
历史总积分:50
发表于:2019/4/4 10:29:06
Rexroth伺服驱动器报代码F281故障,该伺服驱动器还有维修的价值么?
[此贴子已经被jint于2019/4/4 10:45:21编辑过]
23875
cgmguangming
文章数:4515
年度积分:973
历史总积分:23875
西门子接触器(三)
发表于:2019/4/5 1:55:19
F281 Mains fault
Cause:
The power supply voltage was not present during operation for at least 3
power periods. As a result, the drive controller was brought to a standstill
according to the set error response.
Remedy:
Check the power supply connection according to the project planning
specifications
很可能是电源问题。
此帖发自论坛手机版
AAA工业电气
文章数:2
历史总积分:50
发表于:2019/8/13 11:09:31
力士乐的任何设备都有维修的价值
125.0077
