运动控制
回帖:0个,阅读:346次 [上一页] [1] [下一页]
822
didihay
文章数:11
历史总积分:822
发表于:2011/11/28 13:59:31
Flying Saw  http://www.chinasrt.com
The invention relates to a fixed-length welded steel production cut-controlled flying saws computer cut to length steel pneumatic control device, characterized by: saw the car in the optical encoder device set to measure the speed and length of the pipe; settings are controllable pan The clamping device for the second error correction residual Length; in electrical circuits using computer control box, the utility model has the advantage of high accuracy, low price, easy installation, low failure rate, easy maintenance, suitable for the existing pneumatic flying fixed-length steel cutting saw improvements, get a higher economic efficiency.
31.2002
