运动控制
回帖:0个,阅读:1012次 [上一页] [1] [下一页]
1120
lightwhite
文章数:52
历史总积分:1120
08年优秀博客奖
发表于:2008/10/14 10:14:00
step 1: drive mechanism
the sizing process begins by identifying the drive mechanism to be used
obtaining the design specifics such as the inertias, efficiencies and dimensions of all components
identify mechanical constraints such as torque and force limits that must not be exceeded
the following drive mechanisms are available:
1.
rotary
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/rotary.htm]
图
[/URL]
2.
belt & pulley
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/beltandpulley.htm]
图
[/URL]
3.
conveyor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/conveyor.htm]
图
[/URL]
4.
dual stage conveyor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/dualstageconveyor.htm]
图
[/URL]
5.
ball screw
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/ballscrew.htm]
图
[/URL]
6.
rack & pinion
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/rackandpinion.htm]
图
[/URL]
7.
dual stage rack & conveyor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/dualstagerackandconveyor.htm]
图
[/URL]
8.
pin roller
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/pinroller.htm]
图
[/URL]
9.
winder center driven
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/windercenter.htm]
图
[/URL]
10.
winder surface driven
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/windersurface.htm]
图
[/URL]
11.
linear motor
[URL=mk:@msitstore:d:\baumueller\sizemaxx\help\help1033.chm::/linearmotordrivemechanics.htm]
图
[/URL]
然后是选择不同的机械结构计算相应机械惯量,以及各类极限值。
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=64227&Name=lightwhite
工控技术类blog
专注PLC、伺服、运动控制、系统集成。
31.2002
