西门子SIEMENS
回帖:3个,阅读:1708 [上一页] [1] [下一页]
1090
dfdfdsfs
文章数:17
历史总积分:1090
发表于:2006/11/27 22:02:00
西门子plc中命令fr用在什么情况下,那个说明看不懂
1000
junifor
文章数:5
历史总积分:1000
发表于:2006/11/28 13:18:00
不明白你说的啥意思
999
huzhike
文章数:4
历史总积分:999
发表于:2006/11/28 15:01:00
我也不明白说得什么意思!?
致穷无非讨口 不死总得出头
1073
jarryzhou
文章数:26
历史总积分:1073
发表于:2006/11/28 19:19:00
When RLO transitions from "0" to "1", FR <counter> clears the edge-detecting flag that is used for setting and selecting upwards or downwards count of the addressed counter. Enable counter is not required to set a counter or for normal counting This means that in spite of a constant RLO of 1 for the Set Counter Preset Value, Counter Up, or Counter Down, these instructions are not executed again after the enable.
允许指令(FR)只有在逻辑操作结果(RLO)由0跳变为1时,才对计数器进行允许操作.CPU只在正边沿信号时执行FR指令.
例子:
STL Explanation
A I 2.0 //检查输入 I 2.0的信号状态.
FR C3 //当A 2.0信号状态从0变为1的时候启用计数器 C3
109.2007
