普洛菲斯Pro-face
回帖:7个,阅读:2297次 [上一页] [1] [下一页]
1046
bhzero2008
文章数:16
历史总积分:1046
发表于:2006/10/24 12:00:00
请八百壮士详细介绍一下D-Script语言
以及GP存储区中LS0000-LS0019每位的详细功能.
期待你的回复并不胜感谢!!!
[此贴子已经被作者于2006-10-24 12:05:36编辑过]
15179
风之力 版主
文章数:6442
历史总积分:15179
发表于:2006/10/24 21:26:00
自己看书+实验,比别人讲的好!
1046
bhzero2008
文章数:16
历史总积分:1046
发表于:2006/10/25 17:38:00
楼上有相关书籍能介绍一下吗?我也去买一本学学。
15179
风之力 版主
文章数:6442
历史总积分:15179
发表于:2006/10/25 19:51:00
Proface软件里就自带说明书的...你可以自己查查。
1376
qiandragon
文章数:204
历史总积分:1376
发表于:2006/10/30 14:18:00
掌握好LS0000-LS0019还是能为编程省不少时间的
1046
bhzero2008
文章数:16
历史总积分:1046
发表于:2006/10/31 9:07:00
谢谢大家的帮助.不过能说的更详细就好了.
15179
风之力 版主
文章数:6442
历史总积分:15179
发表于:2006/10/31 12:57:00
Set Date                LS0012
Change Screen No LS0008
Current Time LS0005
Current Month LS0003
Current Year LS0002
Error Status LS0001
Display Screen No LS0000
Current Date LS0004
Common Relay Info LS2032
Window Reg. No LS0017
Window Control LS0016
Control                LS0014
Set Time                LS0013
Display On/Off LS0009
Set Month                LS0011
Set Year                LS0010
Window Y Coordinate LS0019
Window X Coordinate LS0018
Base Screen Info LS2033
1 Sec Binary Counter LS2035
Tag Scan Time LS2036
SIO Cycle Time LS2037
Tag Scan Counter LS2038
SIO Error Code LS2039
max Token Circ Speed LS2040
min Token Circ Speed LS2041
BCD error (D-Script) LS203207
PLC monopoly LS000607
Set Value Written LS000603
Now Printing LS000602
PLC Error                LS000111
Timer Clock Error LS000110
Initializtion Req'd LS000109
SIO Over-Run Error LS000106
SIO Parity Error LS000105
SIO Framing Error LS000104
Mem. Checksum Error LS000103
System ROM/RAM ErrorLS000102
Toggles during comms LS203201
Window Order Change LS001601
FD- SRAM<->LS Xfer LS203211
FD-SRAM Backup Fail LS203209
Zero Div. (D-Script) LS203208
K-tag Entry Error LS000608
SRAM data deleted LS203206
Always off                LS203205
Always on                LS203204
Init Scrn Displayed LS203203
Tag Scan complete LS203202
AUX Output ON/OFF LS001405
Comm Error(D-Script) LS203212
Window Displ. ON/OFF LS001600
Hard Copy O/P ON/OFFLS001411
VGA Display ON/OFF LS001408
PLC Monopoly ON/OFF LS001407
FD- PLC to SRAM Fail LS203210
Buzz Enable/Disable LS001404
Start Printing LS001402
Buzzer ON                LS001401
Backlight OFF LS001400
Clock Data Write LS001015
1046
bhzero2008
文章数:16
历史总积分:1046
发表于:2006/11/12 18:38:00
非常感谢风之力大哥!
