嵌入式系统
回帖:0个,阅读:900次 [上一页] [1] [下一页]
1005
zhoooou
文章数:1
历史总积分:1005
发表于:2006/9/2 10:49:00
Feature:
+ 200MHZ ARM920T processor with MMU
+ 100MHZ high speed SDRAM, 32MB on-board
+ 128KB NOR-flash for boot loader
+ 32/64MB on-board NAND-flash for LINUX kernel and root file system
+ Two RS232 serial ports, full-modem and non-modem respectively
+ 10/100M Ethernet connection
+ Double USB hosts
+ USB slave – Philips PDIUSBD12 full speed device
+ Stereo audio input and output
+ Battery backed on-board RTC (external DS1337S)
+ I2C Bus
+ Watchdog timer
+ 5-channel ADC
+ 28 PIO connector
+ Extended static memory bus
+ SPI bus connector
+ Power switch
+ 5V DC power supply @500mA consumption
+ 20-pin JTAG connector
+ Compact size 110 x 120 cm2
+ Full-featured bootloader TinyBOOT,
+ ARM Linux OS, 2.6.x version
+ YAFFS file system support
+ Temperature range: 0°C to +70°C( -40°C to +85°C also available if requested)
http://www.tiny-tech.biz/products.html
Full-featured bootloader for EP93XX:
+ RS232 serial console
+ Raw NAND flash read/write/erase
+ Direct YAFFS image write to NAND flash
+ Network utilties: TFTP, BOOTP, PING, ARP
+ Boot Linux Kernel
+ MD5 utility
+ Memory dump/poke utility
+ Command cache support
http://www.tiny-tech.biz/software.html
请联系:
[EMAIL]contact@tiny-tech.biz[/EMAIL]
46.8329
