回帖:1个,阅读:4566 [上一页] [1] [下一页]
931
yjs2000
文章数:24
历史总积分:931
发表于:2001/5/14 10:24:00
FX2n-4AD模块的使用说明书其中BFM#1—#4的说明有一段英文如下:Contains the number of samples(1 to 4096) to be used for an averaged result. the default settilg is 8- normal speed. high speed operation can be selected with a value of 1.
#5-#8的说明为:these buffer memories contain the averaged input values for the number of samples entered for the channel in buffer memories #1 to #4 respectively.
这两段我看不懂,请指教。
1252
bx_7777
文章数:53
历史总积分:1252
发表于:2001/5/16 7:04:00
模块初始化时的用TO命令向模块写入的值。
