单片机论坛
回帖:0个,阅读:1931次 [上一页] [1] [下一页]
1005
ln-tl022
文章数:1
历史总积分:1005
发表于:2006/5/23 14:34:00
我是一新手,在使用keil对一asm文件编译时出现如下信息:
Build target 'Target 1'
linking...
BL51 BANKED LINKER/LOCATER V5.03 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002
"STARTUP.obj",
"51.obj"
TO "p89c58"
RAMSIZE(256)
*** WARNING L5: CODE SPACE MEMORY OVERLAP
   TO:      0002H
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
   SYMBOL:  ?C_START
   MODULE:  STARTUP.obj (?C_STARTUP)
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
   SYMBOL:  ?C_START
   ADDRESS: 4587H
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 45C0H BYTE (871%) *
Program Size: data=9.0 xdata=0 code=17804
LINK/LOCATE RUN COMPLETE.  3 WARNING(S),  0 ERROR(S)
   TO:      0002H
   SYMBOL:  ?C_START
   SYMBOL:  ?C_START
   ADDRESS: 4587H
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
   MODULE:  STARTUP.obj (-----)
   LIMIT:   0800H BYTES
Target not created
请问上面的警告是什么意思?怎么解决?谢谢!!!
31.2002
