单片机论坛
回帖:0个,阅读:1025次 [上一页] [1] [下一页]
1017
caihengda
文章数:4
历史总积分:1017
发表于:2006/5/4 14:29:00
void lcd(lcd_state)
 switch(lcd_state)
    case ''''0'''':
         uchar code dis1[14] = "input v power";
         uchar code dis2[4] = current_temp;
         uchar code dis3[2] = "v";
         lcd_test(dis1[14],dis2[4],dis3[2]);
    break;
    case ''''1'''':
         uchar code dis1[14]="output v batt";
         uchar code dis2[4]=current_temp;
         uchar code dis3[2]="v";
    break;
但在编译时在
uchar code dis1[14] = "input v power";  等后面总出现
Error 51 "E:\caihengda\kaiguandianyuan\caihengda.c" Line 351(16,17): A numeric expression must appear here
搞几天没有搞清楚,请教各位大侠
[此贴子已经被作者于2006-5-4 14:31:54编辑过]
31.2002
