现场总线
回帖:0个,阅读:1098次 [上一页] [1] [下一页]
1005
shenyuok
文章数:1
历史总积分:1005
发表于:2006/3/16 18:14:00
Gather_00_log:
FUNCTION
Gather_00_log()
INT Gather_00_Rand;
 M_00_GL_FLAG = 0;
 M_00_MAIN_RAND = Rand(32767);
 WHILE M_00_MAIN_RAND = 0 DO
       M_00_MAIN_RAND = Rand(32767);    END
 TagWrite("S_00_MAIN_RAND",M_00_MAIN_RAND);  Sleep(4);
 Gather_00_Rand = TagRead("S_00_MAIN_RAND");
M_00_MAIN_CON = TagRead("S_00_MAIN_CON");
 IF Gather_00_Rand = M_00_MAIN_RAND AND M_00_MAIN_CON = 3 THEN
    TagWrite("S_00_MAIN_CON",2);     Sleep(35);
    WHILE BIAOZHI = 1 DO
          Sleep(5);
    END(如果BIAOZHI = 1说明有其它井怎在传输采集好的功图文件,所以一直等待到BIAOZHI = 0为止)
    Tran_00_File();
    CONVERT_00_File();
 END
END
FUNCTION
Tran_00_File()
STRING Clear_Str;
 BIAOZHI = 1;
 IF D_COMPUTER_STIME = 1 THEN
    Clear_Str = "^"c:\SIXNET Tools\Programs\sxlogview.exe^" ^"E:\工程文件\sixnet\S19_1900.6PJ^" -clear -Device=Ethernet -IPaddr=141.0.0.17 -Transfer=^"Trans_S_1900^"";
 ELSE
    Clear_Str = "^"c:\SIXNET Tools\Programs\sxlogview.exe^" ^"E:\工程文件\sixnet\S19_1900.6PJ^" -clear -Device=Ethernet -IPaddr=141.0.0.17 -Transfer=^"Trans_C_1900^"";
 END
 Exec(Clear_Str,6);
 Sleep(120);
 TagWrite("S_00_MAIN_RAND",-1);
 TagWrite("S_00_MAIN_CON",0);
 BIAOZHI = 0;
END
FUNCTION
CONVERT_00_File()STRING Log_File_Name,Read_File_Str,Start_Data,Start_Time,Mid_Data,Mid_Time,Write_File_Str;
INT HFile_Sxstatus,RECORD_SIZE,End_Flag,Start_Ms,Mid_Ms,Start_Time_Ms,Read_Str_length,
   Mid_Time_Ms,Period_Sec,i_for;
REAL k_00,w_00,t_00,Mid_WeiYi_00;
    Log_File_Name = "D:\DATA\LOG\LOG_1900_S.csv";
 ELSE
    Log_File_Name = "D:\DATA\LOG\LOG_1900_C.csv";
 END
 ErrSet(1);
 HFile_Sxstatus = FileOpen(Log_File_Name,"r");
 IF HFile_Sxstatus <> -1 THEN
    Read_File_Str = FileReadLn(HFile_Sxstatus);
    End_Flag = FileEOF(HFile_Sxstatus);
    RECORD_SIZE = 1;
    Start_Data = StrLeft(Read_File_Str,10);
    Start_Time = StrMid(Read_File_Str,11,8);
    Start_Ms = StrToInt(StrMid(Read_File_Str,20,3));
    Start_Time_Ms = StrToDate(StrMid(Start_Data,0,4)+"-"+StrMid(Start_Data,5,2)+"-"+StrMid(Start_Data,8,2)) + StrToTime(Start_Time);
    Start_Time_Ms = Start_Time_Ms * 1000 + Start_Ms;
    DL_TIME_ARRAY_00[0] = Start_Time_Ms;
    Read_Str_length = StrSearch(20,Read_File_Str,",");
    PT_ZAI_ARRAY_00[0] = StrToReal(StrMid(Read_File_Str,Read_Str_length + 1,5))*150/32767;
    WHILE End_Flag <> 1 DO
       Mid_Data = StrLeft(Read_File_Str,10);
       Mid_Time = StrMid(Read_File_Str,11,8);
       Mid_Ms = StrToInt(StrMid(Read_File_Str,20,3));
       Mid_Time_Ms = StrToDate(StrMid(Mid_Data,0,4)+"-"+StrMid(Mid_Data,5,2)+"-"+StrMid(Mid_Data,8,2)) + StrToTime(Mid_Time);
       Mid_Time_Ms = Mid_Time_Ms * 1000 + Mid_Ms;
       IF Mid_Time_Ms - Start_Time_Ms > 60000 THEN
          RECORD_SIZE = 0;
          Start_Time_Ms = Mid_Time_Ms;
          Start_Data = Mid_Data;
          Start_Time = Mid_Time;
       END
       DL_TIME_ARRAY_00[RECORD_SIZE] = Mid_Time_Ms;
       PT_ZAI_ARRAY_00[RECORD_SIZE] = StrToReal(StrMid(Read_File_Str,Read_Str_length + 1,5))*150/32767;
       IF End_Flag = 1 THEN
          Period_Sec = Mid_Time_Ms - Start_Time_Ms;
       END
       RECORD_SIZE = RECORD_SIZE + 1;
    END
    FileClose(HFile_Sxstatus);
    ErrSet(0);
 END
 Log_File_Name = "D:\DATA\LOG_1900\" + StrMid(Start_Data,0,4) + "\LOG_1900 "  + StrMid(Start_Data,0,4) + "-"  + StrMid(Start_Data,5,2)
           + "-"  + StrMid(Start_Data,8,2) + " " + StrLeft(Start_Time,2) + "h" + StrMid(Start_Time,3,2) + "m.csv";
 ErrSet(1);
 HFile_Sxstatus = FileOpen(Log_File_Name,"A");
 HFile_Sxstatus = FileOpen(Log_File_Name,"W");
 FileWriteLn(HFile_Sxstatus,"ms of Period:");
 FileWriteLn(HFile_Sxstatus,IntToStr(Period_Sec));
 FileWriteLn(HFile_Sxstatus,"Size of Record:");
 FileWriteLn(HFile_Sxstatus,IntToStr(RECORD_SIZE));
 FileWriteLn(HFile_Sxstatus,"WeiYi,PT_ZAI");
 FileWriteLn(HFile_Sxstatus,RealToStr(D_00_CC,5,3) + "," + RealToStr(PT_ZAI_ARRAY_00[0],5,2));
 k_00 = D_00_QB/D_00_LG;
 w_00 = (2*Pi())/Period_Sec;
 FOR i_for = 1 TO RECORD_SIZE - 1 DO
     t_00 = DL_TIME_ARRAY_00[i_for] - Start_Time_Ms;
     Mid_WeiYi_00 = (D_00_CC/2)*(1+Cos(w_00*t_00)-(1/k_00)*(1-Sqrt(1-Pow(k_00,2)*Pow(Sin(w_00*t_00),2))));
     FileWriteLn(HFile_Sxstatus,RealToStr(Mid_WeiYi_00,5,3) + "," + RealToStr(PT_ZAI_ARRAY_00[i_for],5,2));
 END
 ErrSet(0);
END
46.8003
