回帖:1个,阅读:1000 [上一页] [1] [下一页]
1127
luliqiang
文章数:48
历史总积分:1127
发表于:2006/2/28 15:18:00
[size=3][size=2]我现在想用FM353精确的发出单个的脉冲,到底怎么用定时器来实现,比如我如果给10Hz的速度,如果用定时器定时1S,就发出10个脉冲,下面是我的主程序,不能达到我所说的那样,请哪位高手给我指点一下。
     L     B#16#2
     L     "DB_FM".MODE_IN
     ==I
     JC    JOG
     JU    END
JOG:  A     I      0.6
     JC    STP
     A     I      0.5
     JC    S2
     SET
     =     "DB_FM".RESET_AX
     S     "DB_FM".CLEV_EN             // Transfer velocity levels
     CLR
     =     "DB_FM".DIR_M
     =     "DB_FM".DIR_P
     L     L#0
     T     "DB_FM".CLEVEL_1
     T     "DB_FM".CLEVEL_2
     JU    END
S2:   L     L#200                       // Entry of default values
     T     "DB_FM".CLEVEL_2            // Value for velocity level 1
     L     B#16#2
     T     "DB_FM".MODE_TYPE
     SET
     =     "DBEX".EX1.DIR_P
     CLR
     =     "DBEX".EX1.DIR_M
     A     "DBEX".EX1.DIR_M            // Travel - command
     =     "DB_FM".DIR_M
     A     "DBEX".EX1.DIR_P            // Travel + command
     =     "DB_FM".DIR_P
     JU    END
STP:  L     L#0                         // Entry of default values
     L     B#16#2
     T     "DB_FM".MODE_TYPE
     SET
     =     "DBEX".EX1.DIR_P
     CLR
     =     "DBEX".EX1.DIR_M
     =     "DB_FM".DIR_M
     =     "DB_FM".DIR_P
     A     I      0.4
     JCN   END
     A     I      0.4
     L     S5T#1S
     SD    T      0
     L     L#10                        // Entry of default values
     L     B#16#2
     T     "DB_FM".MODE_TYPE
     SET
     =     "DBEX".EX1.DIR_P
     CLR
     =     "DBEX".EX1.DIR_M
     =     "DB_FM".DIR_P
     =     "DB_FM".DIR_M
     A     T      0
     R     "DB_FM".DIR_P
1127
luliqiang
文章数:48
历史总积分:1127
发表于:2006/3/2 16:32:00
哪位高手给指点一下啊!!多谢了
46.8003
