西门子SIEMENS
回帖:0个,阅读:1142 [上一页] [1] [下一页]
1018
xinshi9
文章数:5
历史总积分:1018
发表于:2005/10/31 11:43:00
求助:CP340的485通讯发送问题
   调用FB3的程序如下,我在DB31里面的数据是Byte,奇怪的是不管我怎么改变数据,
我测得的发送口上的数据总是不变,感觉就是好像发送的时候根本就不是在发送我
想要发送的数据。我看到一位大侠说用ASCII通信协议时,还要用一个DB设置协议,
是不是这个问题,怎么设?我的调用FB3的方法,发送数据的指向不对吗?作为新
手,我怀疑我是不是有个基本错误。请指教。
     L     256                         //LADDR
     T     "SEND_WDB".LADDR
     L     2
     T     "SEND_WDB".LEN              //LEN
     L     31                          //DB_NO
     T     "SEND_WDB".DB_NO
     L     0                           //DBB_NOO
     T     "SEND_WDB".DB_NOO
// SEND with instance DB
     CALL  "P_SEND" , "DB_SEND"
      REQ   :="SEND_WDB".REQ
      R     :="SEND_WDB".R
      LADDR :="SEND_WDB".LADDR
      DB_NO :="SEND_WDB".DB_NO
      DBB_NO:="SEND_WDB".DB_NOO
      LEN   :="SEND_WDB".LEN
      DONE  :="SEND_WDB".DONE
      ERROR :="SEND_WDB".ERROR
      STATUS:="SEND_WDB".STATUS
// generate edge for SEND_REQ
     AN    "SEND_WDB".REQ              //SEND_REQ
     S     "SEND_WDB".REQ              //set SEND_REQ
     O     "SEND_WDB".DONE             //SEND_DONE
     O     "SEND_WDB".ERROR            //SEND_ERROR
     R     "SEND_WDB".REQ              //reset SEND_REQ
// verify "cycle without error"
     AN    "SEND_WDB".DONE             //verify SEND_DONE
     JC    CHER                        //if SEND_DONE = 0, jump to CHER
//and check SEND_ERROR
// "cycle without error"
//  SEND_DONE = 1
     L     "SEND_WDB".CONT_OK          // "cycle without error"
     +     1                           //increment counter
     T     "SEND_WDB".CONT_OK
     L     "SEND_WDB".STATUS
     T     "SEND_WDB".STATUS_SAV       //save STATUS
     NOP   0
     NOP   0                           //additional user functions
     NOP   0
     BE
// verify "cycle with error"
// SEND_ERROR = 1
CHER: AN    "SEND_WDB".ERROR            //check SEND_ERROR
     BEC                               //close the block if no error has occurred
// "cycle with error"
     L     "SEND_WDB".CONT_ERR         // "cycle with error"
     T     "SEND_WDB".CONT_ERR
     L     "SEND_WDB".STATUS
     NOP   0
     NOP   0                           //error handling
     NOP   0
     BE
46.8003
