变频器论坛
回帖:5个,阅读:661次 [上一页] [1] [下一页]
800
yjuwlufg7700
文章数:42
历史总积分:800
发表于:2024/3/21 0:22:23
单板测试运行怎么屏蔽六路出波型?现在是能运行但没有动态电压。
[此贴子已经被jint于2024/3/22 9:24:57编辑过]
1326893350
文章数:1085
年度积分:996
历史总积分:11970
发表于:2024/3/21 11:12:33
顶一个!表情抛砖引玉表情
森林之王
53
Cnlong
文章数:29
年度积分:53
历史总积分:53
发表于:2024/3/21 20:26:36
Short-circuit the input phase loss optocoupler then u can check the six signals of igbt
Cnlong
文章数:29
年度积分:53
历史总积分:53
发表于:2024/3/21 20:40:04
for mitsu a700 series, you don't need to fake the feedback pulse signal of igbt. just fake the DC bus voltage measurement circuit and short circuit the secondary of input phase loss optocoupler and done. because for mitsu a700, when input phase loss optocoupler don't active, vfd will show normal display and u still running on panel like no matter happened, but the pulse signal of igbt still hide. just like that
yjuwlufg7700
文章数:42
历史总积分:800
发表于:2024/3/22 20:25:15
以下是引用Cnlong在2024/3/21 20:26:36的发言:
短接了之后,报欠压。不短,还可以运行。
Cnlong
文章数:29
年度积分:53
历史总积分:53
发表于:2024/3/23 8:02:17
以下是引用yjuwlufg7700在2024/3/22 20:25:15的发言:
短接了之后,报欠压。不短,还可以运行。
Please go to the parameters to see the DC bus voltage. If there is no DC bus voltage, it means you have not faked the DC bus signal.  Even if there is no dc bus voltage, the circuit board will still be normal but it will not do anything, only when you short circuit the input phase loss optocoupler, will the circuit board actually work.
117.1216
