施耐德电气论坛
回帖:3个,阅读:1842 [上一页] [1] [下一页]
2015
万泉河.
文章数:915
年度积分:-100
历史总积分:2015
品牌积分(施耐德):93
发表于:2021/8/16 20:52:04
没错, 贝加莱标准化项目已经完成了。 也已经写了文章+总结
《【万泉河】贝加莱PLC标准化项目开发,一周完成》
先发在其他空间了,本站稍后发。
然后马不停蹄又搞施耐德了。
然而一上来就遇到个弼马温。写个最简单的累加程序,下载到仿真去, 多则一个小时,短则几分钟,一会儿就跳掉了。 截图在最后。 有要源程序帮忙分析的,留言稍后想办法传上。
有对施耐德SO系统熟悉的大神麻烦解答一下. 杠精请绕路
   <Entry severity="exception" component="CmpIecTask" user="nobody" timestamp="2021/8/16 12:22:20">*EXCEPTION* Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="exception" component="CmpIecTask" user="nobody" timestamp="2021/8/16 12:03:52">*EXCEPTION* Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="exception" component="CmpIecTask" user="nobody" timestamp="2021/8/16 10:30:30">*EXCEPTION* Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 9:00:06">application=Sim.MyController.Application, dataid{d464fbcf-00000000-00000000-00000000}</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 9:00:06">application=Sim.MyController.Application, codeid={b0dd5796-00000000-00000000-00000000}</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 9:00:06">Application Sim.MyController.Application loaded [Download]</Entry>
   <Entry severity="error" component="CmpChannelServer" user="nobody" timestamp="2021/8/16 8:59:46">ServerAppHandleRequest returned 28</Entry>
   <Entry severity="error" component="CmpChannelServer" user="nobody" timestamp="2021/8/16 8:59:38">ServerAppHandleRequest returned 28</Entry>
   <Entry severity="error" component="CmpApp" user="nobody" timestamp="2021/8/16 8:59:36">Online change denied. Application Sim.MyController.Application is in exception state!</Entry>
   <Entry severity="error" component="CmpChannelServer" user="nobody" timestamp="2021/8/16 8:59:30">ServerAppHandleRequest returned 28</Entry>
   <Entry severity="exception" component="CmpIecTask" user="nobody" timestamp="2021/8/16 8:56:31">*EXCEPTION* Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="exception" component="CmpSchedule" user="nobody" timestamp="2021/8/16 8:56:31">*EXCEPTION* Omitted cycle Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 8:56:18">application=Sim.MyController.Application, dataid{b7969497-00000000-00000000-00000000}</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 8:56:18">application=Sim.MyController.Application, codeid={4d3c60bf-00000000-00000000-00000000}</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 8:56:18">Application Sim.MyController.Application loaded [Download]</Entry>
   <Entry severity="exception" component="CmpIecTask" user="nobody" timestamp="2021/8/16 8:54:46">*EXCEPTION* Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="exception" component="CmpSchedule" user="nobody" timestamp="2021/8/16 8:54:45">*EXCEPTION* Omitted cycle Watchdog Sim.MyController.Application MAST</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 8:54:01">application=Sim.MyController.Application, dataid{b7969497-00000000-00000000-00000000}</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 8:54:01">application=Sim.MyController.Application, codeid={2b853a84-00000000-00000000-00000000}</Entry>
   <Entry severity="information" component="CmpApp" user="nobody" timestamp="2021/8/16 8:54:01">Application Sim.MyController.Application loaded [Download]</Entry>
   <Entry severity="warning" component="CmpRetain" user="nobody" timestamp="2021/8/16 8:54:01">Retains are not stored for Sim.MyController.Application</Entry>
   <Entry severity="information" component="CmpRouter" user="nobody" timestamp="2021/8/16 7:46:30">Setting router 0 address to (0000:4001)</Entry>
   <Entry severity="information" component="CM" user="nobody" timestamp="2021/8/16 7:46:30">CODESYS Control ready</Entry>
   <Entry severity="information" component="CmpRouter" user="nobody" timestamp="2021/8/16 7:46:30">Setting router 0 address to (0001)</Entry>
   <Entry severity="information" component="CmpBlkDrvShm" user="nobody" timestamp="2021/8/16 7:46:30">Local address (BlkDrvShm) set to 1</Entry>
   <Entry severity="information" component="CmpRouter" user="nobody" timestamp="2021/8/16 7:46:30">Network interface BlkDrvShm registered</Entry>
   <Entry severity="information" component="CmpGwCommDrvDirectCall" user="nobody" timestamp="2021/8/16 7:46:30">Listening for connections on SharedMemory: SimulationGWDirectCallShm3428</Entry>
   <Entry severity="information" component="CmpRouter" user="nobody" timestamp="2021/8/16 7:46:30">Network interface BlkDrvTcp registered</Entry>
   <Entry severity="information" component="CmpBlkDrvTcp" user="nobody" timestamp="2021/8/16 7:46:30">Client is disabled</Entry>
   <Entry severity="information" component="CmpBlkDrvTcp" user="nobody" timestamp="2021/8/16 7:46:30">Local network address: 127.0.0.1</Entry>
   <Entry severity="information" component="CmpBlkDrvTcp" user="nobody" timestamp="2021/8/16 7:46:30">Only allowed peer ip address: 127.0.0.1</Entry>
   <Entry severity="information" component="CmpBlkDrvTcp" user="nobody" timestamp="2021/8/16 7:46:30">Local ip address of the only used network adapter: 127.0.0.1</Entry>
   <Entry severity="information" component="CmpChannelServer" user="nobody" timestamp="2021/8/16 7:46:30">8 channels available, each of the size 100000 Bytes</Entry>
   <Entry severity="information" component="CmpChannelMgr" user="nobody" timestamp="2021/8/16 7:46:30">Running as network client</Entry>
   <Entry severity="information" component="CmpChannelMgr" user="nobody" timestamp="2021/8/16 7:46:30">Running as network server</Entry>
PLC标准化编程
2660
yqyyqy 版主
文章数:258
年度积分:71
历史总积分:2660
品牌积分(施耐德):115
发表于:2021/8/17 8:01:19
是不是某段程序执行时间太长触发看门狗了?
2015
万泉河.
文章数:915
年度积分:-100
历史总积分:2015
品牌积分(施耐德):93
发表于:2021/8/17 8:27:09
回复 #1楼 yqyyqy
只有一句程序, A=A+1
PLC标准化编程
53
wcsxzg007
文章数:29
年度积分:53
历史总积分:53
品牌积分(施耐德):19
发表于:2021/9/16 13:59:14
INT 超限了!!!
