人机界面
回帖:3个,阅读:11526次 [上一页] [1] [下一页]
772
wihelm
文章数:68
历史总积分:772
发表于:2017/12/4 11:36:54
系统win7 64 旗舰,原装系统。试了几次了,还是不行,消息队列已装。
错误代码:
2017.12.04 09:55:44 - Year.Month.Day - Log start
BUNDLE: SIMATIC WinCC Professional V14.0 SP1
SEBU Version: Professional:TIA.rgs.RTM_14000100:V14.00.01.00_12.01.00.01
OS: Microsoft Windows 7 专业版  Professional, Service Pack 1, 64-bit, build 7601
COMMANDLINE: C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant\401\SIA2.exe /starter /bundlepath=\\VMWARE-HOST\SHARED FOLDERS\SHARE\WINCC PROF V14SP1\InstData
INSTALLDIR: C:\Program Files\Siemens\Automation\
SETUPLANGUAGE: 2052
PRODUCTLANGUAGES: 1033;2052
There are NO severe messages before the installation
10:45:49 |ERROR    AdsWorkerClassicComponent::OnWorkerCompleted():  - ClassicComponent setup result: Unexpected exception
10:45:49 | FAIL!                     SetupUnit (S7DOS64), Failed -  - ClassicComponent, AddLocal
10:50:12 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:50:12 | FAIL!                     SetupUnit (TIAP_SIMATIC), Failed -  - PlusOptional, AddLocal
10:51:10 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:51:10 | FAIL!                     SetupUnit (STEP7), Failed -  - PlusOptional, AddLocal
10:52:14 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:52:14 | FAIL!                     SetupUnit (HM_AllEditions), Failed -  - PlusOptional, AddLocal
10:52:40 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:52:40 | FAIL!                     SetupUnit (HM_NoBasic), Failed -  - PlusOptional, AddLocal
10:52:58 |ERROR    AdsWorkerClassicProduct::OnWorkerCompleted():  - ClassicProduct setup result: :
10:52:58 | FAIL!                     SetupUnit (Prosave), Failed -  - ClassicProduct, AddLocal
10:54:18 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:54:18 | FAIL!                     SetupUnit (TIA_ES), Failed -  - PlusOptional, AddLocal
10:54:21 |ERROR    AdsWorkerSetupPackage::OnWorkerCompleted():  - SetupPackage setup failed due to unknown error
10:54:21 | FAIL!                     SetupUnit (TIA_ES32), Failed -  - PlusOptional, AddLocal
11:00:51 |ERROR    AdsWorkerForeignExe::GetInstallResult():  - -1: assuming unknown error, because return value <> 0 and either OK- nor ERROR-values are defined. Please check the corresponding log file for more detailed information
11:00:51 | FAIL!                     StartApplAfter (TIAP14::[INSTALLDIR]BIN\SIEMENS.AUTOMATION.GENERATOR.FRAMEWORK.EXE), Failed
11:01:08 | OK                        StartApplAfter (TIAP14::C:\WINDOWS\SYSWOW64\S7EPATSX.EXE), Complete
11:01:55 | OK                        StartApplAfter (TIAP14::C:\WINDOWS\SYSWOW64\S7EPAESX.EXE), Complete
11:01:55 |ERROR    AdsWorkerForeignExe::GetInstallResult():  - -1: assuming unknown error, because return value <> 0 and either OK- nor ERROR-values are defined. Please check the corresponding log file for more detailed information
11:01:55 | FAIL!                     StartApplAfter (TIAP14::[INSTALLDIR]BIN\SIEMENS.SIMATIC.HWCN.INTERPRETER.IG.GSD.GENERATOR.EXE), Failed
11:02:29 | END. Execution completed.
Intermediate ExitCode after execution queue: 1603
Errors: 10
Warnings: 0
如图所示:
20分悬赏
28510
ytleaderplc
文章数:11884
年度积分:1470
历史总积分:28510
发表于:2017/12/4 16:07:17
电脑系统的问题。格式化重新安装试试。博途软件有时候安装需要好几天时间,折磨人的。
16694
李东泽 版主
文章数:7102
历史总积分:16694
英威腾变频器(三)
龙诚PLC体验(三)
三菱电机活动(一)
发表于:2017/12/4 17:02:32
你的电脑软件是正版的吗!
9556
6926792
文章数:1133
年度积分:245
历史总积分:9556
发表于:2017/12/4 23:46:28
建议装双系统,一个系统装全英文里面只放西门子软件,我们公司都是这么干的!
自古人生与世,需有一技之长;我辈既务斯业,须当专心用功;
