回帖:2个,阅读:1574次 [上一页] [1] [下一页]
651
290998492
文章数:9
历史总积分:651
发表于:2017/2/16 20:28:19
V_M00001 and V_M00033 are both WORD arrays of length 3, for a total of 48 bits in each array. Since Controllers do not recognize arrays, the Length operand has to be set to 3, for the total number of WORDs to be moved. When enabling input V_Q0014 is ON, MOVE_WORD moves 48 bits from the memory location %M00001 to memory location %M00033. Even though the destination overlaps the source for 16 bits, the move is done correctly, except on Series 90-30 CPU351, CPU352, and CPU36x CPUs, which do not allow overlapping.
10分悬赏
14052
蛇会大学
文章数:5038
年度积分:729
历史总积分:14052
2018论坛分享达人
发表于:2017/2/16 22:33:28
就是把寄存器中的数值,复制到另一个寄存器中
敏问找算丁亏楼累
敏问找算哭哲累嘿
敏问够算恐哈做累揍忍没催妹
比漏累伤醒更八音舍黑
我晕能以身问晕陪笨累
21104
pqsh 版主
文章数:7779
年度积分:838
历史总积分:21104
发表于:2017/2/17 8:08:42
复制一组字到另外一个地方,有些允许重叠.
如果我忘了我
请帮忙记得我
pqsh@163,326199298@v&q同号
46.8003
