回帖:3个,阅读:713次 [上一页] [1] [下一页]
译码指令
563
李明旺
文章数:3
历史总积分:563
发表于:2016/6/21 16:42:21
DECO D0 D10 k4谁能拿它当例子给讲讲,谢谢
zhengpan2010
文章数:2684
历史总积分:4632
发表于:2016/6/21 19:28:54
DECB(BINARY DECODING)
Function
DECB decodes one, two, or four-byte binary code data. When one of the specified eight consecutive numbers matches the code data, a logical high value (value 1) is set in the output data bit which corresponds to the specified number. When these numbers do not match, a logical low value (value 0) is set.
Use this instruction for decoding data of the M or T function.
In PMC-SB5/SB6/SB7 for Series 16i/160i/18i/180i/Power Mate i and PMC-SA5 for Series 21i/210i, the setting of the format specification parameter is extended. With this setting, DECB can decode multiple (8* n) bytes.
7830
hnhyczj
文章数:3780
历史总积分:7830
发表于:2016/6/22 9:39:21
看下三菱的编程手册,上面有详细解释。
诚
20178
高雅的雅
文章数:15776
年度积分:-210
历史总积分:20178
发表于:2016/6/22 19:56:31
楼主是不是完全不看编程手册的呀?
46.8003
