工控软件
回帖:1个,阅读:415次 [上一页] [1] [下一页]
1318
666-liuliu
文章数:136
历史总积分:1318
发表于:2013/10/17 22:29:19
诊断信息如下:
Diagnostic buffer of module CPU 412-2 DP
Order No./ Description         Component                     Version
6ES7 412-2XJ05-0AB0           Hardware                       2
- - -                         Firmware                       V 5.1.1
Rack:                         0
Slot:                         3
Serial number: SVPVN398439
Event 1 of 44:  Event ID 16# 2943
I/O access error, writing
P area, double-word access, Access address:    356
FC number:     12
Module address:    344
Requested OB: I/O access error OB (OB122)
Priority class:  1
External error, Incoming event
07:23:21.012 AM  07/31/1996
Event 2 of 44:  Event ID 16# 2942
I/O access error, reading
P area, double-word access, Access address:    358
FC number:     12
Module address:    332
Priority class:  1
Event 3 of 44:  Event ID 16# 2942
P area, word access, Access address:    356
FC number:     12
Module address:    324
Priority class:  1
Event 4 of 44:  Event ID 16# 2943
P area, double-word access, Access address:    316
FC number:     12
Module address:    296
以上诊断信息是何意?是cpu本身出现问题还是与之通讯的站出现问题,或者是什么?谢谢!
6分悬赏
39920
cvlsam 版主
文章数:12785
年度积分:1167
历史总积分:39920
2017论坛贡献奖
2016论坛贡献奖
2013论坛贡献奖
2012论坛贡献奖
2010论坛杰出贡献奖
发表于:2013/10/18 6:16:13
您的问题可能是由于Fc12中对于模块的访问出错导致,请检查Fc12中的编程,例如,由于间接寻址的Bug导致访问地址越界,从而引发模块IO地址访问错误。
Good Luck~
31.2002
