罗克韦尔Rockwell(AB)
回帖:10个,阅读:1728次 [上一页] [1] [2] [下一页]
3151
tjq1976
文章数:440
年度积分:135
历史总积分:3151
发表于:2013/2/25 15:10:55
REVISION HISTORY
 A JAX 2010.01.19 Initial Creation
 B Ready for Source Code Review
 C Updated to Include Source Code Review Comments
 1.0 Released for Internal Testing
 2.0 Released for FAT
 3.0 Released for SAT
1#滤格进水阀 - TAG
 //Input Mapping
   YC011.INP_SwtchOpn := Local:1:I.Data.0;
YC011.INP_SwtchCls := Local:1:I.Data.1;
 //YC011.INP_Fail := 故障状态;
YC011.INP_InptModlHlth := Local:1:I.fault.0 or Local:1:I.fault.1 ;
   YC011.CMD_ModlFltRst := SYSTEM.CMD.AckAllAlrms;
 //Output Mapping
  //Local:3:O.Data.0 := YC011.OUT_Opn;
   Local:3:O.Data.0 := YC011.OUT_Cls;
  YC011.INP_OutptModlHlth := Local:3:I.fault.0 ;
 //Safety Interlocks
   YC011.INP_SftyIntrlk := 0;
 //Process Interlocks
   YC011.INP_PrcsIntrlk := 0;
 //Simulation
   YC011.STS_Sim := SYSTEM.STS.Sim;
1#滤格排水阀 - TAG
 //Input Mapping
   YC012.INP_SwtchOpn := Local:1:I.Data.2;
YC012.INP_SwtchCls := Local:1:I.Data.3;
YC012_Pause_Fdbck  := Local:1:I.Data.12;
 //YC012.INP_Fail := 故障状态;
YC012.INP_InptModlHlth := Local:1:I.fault.2 or Local:1:I.fault.3;
   YC012.CMD_ModlFltRst := SYSTEM.CMD.AckAllAlrms;
 //Output Mapping
  Local:3:O.Data.1 := YC012.OUT_Opn;
   Local:3:O.Data.7 := YC012.OUT_Cls;
  YC012.INP_OutptModlHlth := Local:3:I.fault.1 ;
 //Safety Interlocks
   YC012.INP_SftyIntrlk := 0;
   YC012.INP_PrcsIntrlk := 0;
 //Simulation
   YC012.STS_Sim := SYSTEM.STS.Sim;
1#滤格气冲阀 - TAG
 //Input Mapping
   YC013.INP_SwtchOpn := Local:1:I.Data.4;
YC013.INP_SwtchCls := Local:1:I.Data.5;
 //YC013.INP_Fail := 故障状态;
YC013.INP_InptModlHlth := Local:1:I.fault.4 or Local:1:I.fault.5 ;
   YC013.CMD_ModlFltRst := SYSTEM.CMD.AckAllAlrms;
 //Output Mapping
  Local:3:O.Data.2 := YC013.OUT_Opn;
   //N1:4:O.Data.1 := YC013.OUT_Cls;
  YC013.INP_OutptModlHlth := Local:3:I.fault.2 ;
 //Safety Interlocks
   YC013.INP_SftyIntrlk := 0;
   YC013.INP_PrcsIntrlk := 0;
 //Simulation
   YC013.STS_Sim := SYSTEM.STS.Sim;
1#滤格初滤水放空阀 - TAG
 //Input Mapping
   YC014.INP_SwtchOpn := Local:1:I.Data.6;
YC014.INP_SwtchCls := Local:1:I.Data.7;
 //YC014.INP_Fail := 故障状态;
YC014.INP_InptModlHlth := Local:1:I.fault.6 or Local:1:I.fault.7 ;
   YC014.CMD_ModlFltRst := SYSTEM.CMD.AckAllAlrms;
 //Output Mapping
  Local:3:O.Data.3 := YC014.OUT_Opn;
   //N1:4:O.Data.1 := YC014.OUT_Cls;
  YC014.INP_OutptModlHlth := Local:3:I.fault.3 ;
 //Safety Interlocks
   YC014.INP_SftyIntrlk := 0;
   YC014.INP_PrcsIntrlk := 0;
 //Simulation
   YC014.STS_Sim := SYSTEM.STS.Sim;
在mainprogram树形列表中,其他几个都是梯形图,就这个是高级语言编辑,我看了一下,好像是变量定义以及赋值。这个程序是别人做的,我也不是很明白,初次接触AB的,请专家解释一下,谢谢!
[此贴子已经被作者于2013/2/25 15:11:45编辑过]
3964
www.xutengfei
文章数:818
历史总积分:3964
发表于:2013/2/25 18:22:55
没见过这种程序,根本看不懂啊!
虚心请教,努力学习!
25227
wenquan753
文章数:15252
历史总积分:25227
发表于:2013/2/25 21:48:57
我看不懂
没有接触过@
21218
pqsh 版主
文章数:7799
年度积分:952
历史总积分:21218
发表于:2013/2/26 9:51:05
应该是简单做了些输入输出重新映像。
比如YC012.INP_SwtchOpn := Local:1:I.Data.2;是把本地机架输入模块的第二通道,映像到YC012.。。
Local:3:O.Data.0 := YC011.OUT_Cls;是把YC011映像到本地模块3输出第0通道。
实际的程序里可能用YC012,YC011等来写。
如果我忘了我
请帮忙记得我
pqsh@163,326199298@v&q同号
1151
wantao0916
文章数:73
历史总积分:1151
发表于:2013/2/26 15:52:28
不能上梯形图么?这样非常难看懂。
www.huabo-plc.com
11873
gzg_00
文章数:8995
历史总积分:11873
发表于:2013/3/2 15:25:00
真心看不懂
733
404560861
文章数:21
历史总积分:733
发表于:2013/11/14 18:34:08
不懂
2481
拓海科技
文章数:982
历史总积分:2481
发表于:2013/11/14 18:48:37
单片机的吗
匿名用户
文章数:N/A
年度积分:0
历史总积分:0
发表于:2013/11/14 21:28:35
该用户被锁定,回复内容不予显示!
1096
hhtla2000
文章数:18
历史总积分:1096
发表于:2013/11/20 19:30:57
不懂,梯形图没有嘛
1156.2545
