回帖:1个,阅读:411 [上一页] [1] [下一页]
709
69401342
文章数:5
历史总积分:709
发表于:2012/12/7 17:06:42
下一是CPU的报警记录,跳停时间为05:12:.679,且停后CPU再也起不来了,要重新完全编译下载才起得来,大家帮看看是什么原因跳的(本人是change the only编译和下载,CPU本应不停才对)。
Diagnostic buffer of module CPU 417-4 H
Order No./ Description         Component                     Version
6ES7 417-4HT14-0AB0           Hardware                       1
- - -                         Firmware                       V 4.5.1
Rack:                         0
Slot:                         3
Settings:
  Time including CPU/local time difference (+8 h)
Event 1 of 3000:  Event ID 16# 530D
New startup information in STOP mode
Startup prevented by:
- Memory reset necessary
- STOP request exists
- Cold restart or warm restart necessary
Startup information:
- Time for time stamp at the last backed up power on
- Single processor operation
Current/last startup type:
- Warm restart triggered via MPI
Permissibility of certain startup types:
- Startup not permitted, system memory reset requested
Last valid operation or setting of automatic startup type at power on:
- No startup type/following memory reset
Operating mode: STOP (internal)
Event occurred in the master CPU in rack 0
Incoming event
05:12:.680 5   11/27/2012
Event 2 of 3000:  Event ID 16# 4556
STOP: memory reset request from communication system /inconsistency of the data
Previous operating mode: RUN
Requested operating mode: STOP (internal)
Internal error, Incoming event
05:12:.679 5   11/27/2012
Event 3 of 3000:  Event ID 16# 530D
- Manual warm restart permitted
Operating mode: RUN
Incoming event
Event 4 of 3000:  Event ID 16# 6523
Memory reset request due to error accessing memory submodule
Operating mode: RUN
05:12:.679 5   11/27/2012 (跳停时间)
Event 5 of 3000:  Event ID 16# 38B4
I/O access error when transferring the process image to the output modules leaving state
DP master system ID: 193
Access error occurred with user data
Process image partition no.:  0
Start address of I/O area involved:    816, Length of the area:  64
Requested OB: Program execution error OB (OB85)
Priority class: 25
External error, Outgoing event
05:03:.148 1   11/27/2012 (跳停前一个报警,相差9分钟应该没任何关系)
709
69401342
文章数:5
历史总积分:709
发表于:2012/12/9 19:11:29
求助哈····很郁闷,当时只是点下下载,还没有下载呢~
46.8003
