回帖:0个,阅读:1441次 [上一页] [1] [下一页]
求助 找文章
1020
冬叶
文章数:4
历史总积分:1020
发表于:2005/3/14 18:51:00
谁有中文的Transient stability assessment of systems comprising phase-shifting FACTS  devices by direct methods 全篇文章 有的话 帮个忙 发送到 ll7758lilong.student@sina.com  谢谢了
Rafael Mihali   ,  and Uros Gabrijel
Faculty of Electrical Engineering, University of Ljubljana, Trzaska 25, Ljubljana 1000, Slovenia
Available online 23 January 2004.
Abstract
In this paper the concept of a control Lyapunov function is used to develop control strategies for thyristor-controlled  phase-shifting  transformers (TCPSTs). Two typical representatives of TCPSTs were chosen for consideration: a Quadrature Boosting Transformer (QBT) and a Phase Angle Regulator (PAR). For the case of the QBT we showed that the proposed control law can significantly improve the large signal  stability  in comparison to the control-law-based on the traditionally used injection model proposed in various references. Even if the  system  parameters are estimated very roughly, our proposed strategy gives better results than the ‘traditional’ strategy. Also, some novel energy functions, which consider the action of an optimally controlled TCPST in a single-machine infinite-bus (SMIB)  system,  are presented and validated by a numerical example.
Author Keywords: Author Keywords: Thyristor-controlled  phase-shifting  transformer; Control strategy; Energy function; Direct method
[此贴子已经被作者于2005-3-15 17:09:23编辑过]
2625.097
