回帖:1个,阅读:352次 [上一页] [1] [下一页]
NSD CONTROLLER
1545
qdgeng886
文章数:305
历史总积分:1545
发表于:2011/12/27 13:03:39
Electronic rotary cam switch.
1. Summary
1-1. Summary
[Application]
High speed press, packaging machine, automatic assembly machine, etc.
1-2. Features
(1) Durable Absolute Position Detection
The ABSOCODER detects the rotary position in absolute format. Even if the power supply is
interrupted, the current position can be detected correctly when the power supply is recovered,
eliminating origin-point return.
(2) Highly Accurate Control
The switch ON/OFF positions can be controlled accurately by setting them in increments of 0.1 .
The VARICAM Series electronic cam switch format replaces the conventional mechanical cam switch
format. NSD’s unique absolute position detection unit is incorporated in the detection section, ensuring
highly reliable position detection.
(3) Quick Response
The maximum switch output is 0.1 ms, ensuring very quick response.
(4) Easy Setup Change
Up to 20 programs can be registered. Setup can be changed by simply selecting a different program.
Further, the switch ON/OFF positions can be increased up to 128 points, enabling smooth operation
for a variety of small lot production.
(5) Current Position Output Code
BCD or binary can be selected as the output code of the current position and the rotation speed.
附件:
[本地下载]
2021
sry
文章数:6
历史总积分:2021
发表于:2012/2/25 10:54:53
有没有中文资料?
31.2002
