工控英语角
回帖:0个,阅读:767次 [上一页] [1] [下一页]
14730
lizy 版主
文章数:3701
年度积分:230
历史总积分:14730
发表于:2011/7/19 16:56:07
ABB wins gas order worth more than $30 million in Abu Dhabi
ABB在阿布扎比赢得价值超3千万美元天然气订单
ABB technology to help ensure safety and productivity of sour gas treatment
ABB技术帮助保障酸气处理的安全和生产率
Zurich, Switzerland, July 18 2011 – ABB, the leading power and automation technology group, has won an order worth more than $30 million from Saipem S.p.A. and Samsung Engineering Co., Ltd to provide a range of power and automation equipment for a natural gas processing plant in Abu Dhabi, the United Arab Emirates.
瑞士苏黎世7月18日消息——领先的电力和自动化技术集团ABB从Saipem公司和三星工程公司赢得了一份价值超过3千万美元的订单,为阿拉伯联合酋长国阿布扎比的一间天然气处理厂提供一系列的电力和自动化设备。
The plant is located in the Shah natural gas field 180 kilometers southwest of Abu Dhabi city, and has a daily production target of one billion cubic feet of sour gas. Abu Dhabi is developing its sour, or high sulfur, gas reserves as domestic power consumption soars. The hydrogen sulfide content of the gas must be reduced to acceptable levels before it can be used.
该工厂位于阿布扎比市西南方180公里处的Shah天然气田,每日的生成目标为10亿立方英尺的酸气。随着国内能源消费的大增,阿布扎比正在大力发展其酸气和高含硫气储备量。在可以使用之前,天然气的硫化氢含量必须降低到可接受的水平。
For this project ABB Italy and ABB South Korea will supply low voltage switchgear, intelligent motor control units and variable frequency drives.
ABB意大利公司和ABB韩国公司将为这个项目提供低压开关柜,智能电机控制单元,以及变频器。
“This order is the end result of a successful ‘One ABB’ collaboration between different local teams,” said Tarak Mehta, head of ABB’s Low Voltage Products division. “ABB technology for remote control systems is crucial in order to ensure the functionality and the integration of low-voltage switchgear in modern production plants.”
ABB低压产品部主管Tarak Mehta表示:“这一订单是在‘一个ABB’框架下不同本地团队成功合作的最终成果。ABB的远程控制系统技术也至关重要,以确保在现代化生产工厂里低压开关柜的功能性和一体化。”
The safety of personnel and equipment reliability are key issues for this plant, and played a significant role in the awarding of this contract. ABB’s MNS low-voltage switchgear uses remote control systems and multifunction protection relays that make it the benchmark for operational safety, reliability and quality.
工厂人员和设备可靠性的安全是该工厂的关键问题,并为该合同的签订发挥了重要作用。ABB的MNS低压开关柜使用了远程控制系统以及多功能保护继电器,使其成为运营安全、可靠性和质量的基准。
ABB is a leader in power and automation technologies that enable utility and industry customers to improve their performance while lowering environmental impact. The ABB Group of companies operates in around 100 countries and employs about 124,000 people.
ABB是全球领先的电力和自动化技术企业,致力于帮助电力、公共事业和工业客户提高业绩,同时降低对环境的影响。ABB集团业务遍布全球100多个国家,拥有12.4万名员工。
[此贴子已经被作者于2011/7/19 16:58:36编辑过]
此帖来自中华工控网工控博客。
原文件地址:http://blog.gkong.com/more.asp?id=141124&Name=dreamslzy
31.2002
