工控英语角
回帖:2个,阅读:896 [上一页] [1] [下一页]
到底是谁的错?
24289
sddyzyd
文章数:6952
年度积分:728
历史总积分:24289
发表于:2010/8/12 9:12:54
A man in a hot air balloon realized he was lost. He reduced altitude and spotted a woman below. He descended a bit more and shouted, "Excuse me, can you help? I promised a friend I would meet him an hourago, but I don't know where I am."
The woman below replied, "You are in a hot air balloon hovering approximately 30 feet above the ground. You are between 40 and 41 degrees north latitude and between 59 and 60 degrees west longitude."
"You must be an engineer," said the balloonist.
"I am," replied the woman. "How did you know?"
"Well," answered the balloonist, "everything you told me is technically correct, but I have no idea what to make of you, and the fact is I am still lost. Frankly, you've not been much help so far."
The woman below responded, "You must be in management."
"I am," replied the balloonist, "but how did you know?"
"Well," said the woman, "you don't know where you are or where you are going. You have risen to where you are, due to a large quantity of hot air. You made a promise which you have no idea how to keep, and you expect people beneath you to solve your problems. The fact is you are in exactly the same position you were in before we met, but now, somehow, it's my fault!"
一个男人在热气球上,发现自己迷失了方向。他下降高度,下方有一个妇女。他又下降了一点,大声呼喊,"打扰下,你能帮个忙吗,一个小时以前我答应了一个朋友要和他见面,但现在我不知道我身处何地。”
妇女在下面回答,“你在一个热气球里,大约离地面三十英尺。你在北纬40-41度之间,西经59-60度之间。”
“你必定是个工程设计师,”气球上的男人说。
“我是,”女人回答。“你是怎么知道的?”
“是这样,”气球上的男人说“你告诉我的事在技术上都是正确的,但是我无法理解你的看法,事实是我依旧迷失。坦白说,到目前为止你没帮上我多少。”
下面的妇女回应道,“你一定是在管理部门工作。”
“我是,”气球上的男人回答,“这你是怎么知道的?”
“是啊,”妇女说,“你总是不知道你在哪里,也不知道你要去哪里。你的上升,是由于大量的热气。你对别人许下的承诺,你不知道如何履行,而且你还期望在你下面的人会解决你的问题。事实就是在我们见面之前,我们都在完全相同的立场上,可现在,不知怎么地,却成了我的错了。”
1012
chenyunwen744
文章数:16
历史总积分:1012
发表于:2010/8/13 13:13:56
悄悄的告诉你,你的英语水平还需要继续提高,但精神的却可嘉
20607
qlin 版主
文章数:6709
历史总积分:20607
发表于:2010/8/14 10:15:29
呵呵,丢失了自己。
楼上也可以发点帖子。
欢迎您支持 “中华工控网” 论坛  http://bbs.gkong.com/    “电工技术”版块
各位见谅,谢了!   20170501启
