工控英语角
回帖:2个,阅读:883次 [上一页] [1] [下一页]
汽车电气系统
797
Rita-cq
文章数:26
历史总积分:797
发表于:2010/7/23 22:23:21
电气系统中第一个主要的部件是电池。它用来储存电,用于启动以及在发动机关闭时为钟、收音机和CD播放机等辅助装置供电。第二个主要的部件是起动机,它用于起动发动机。第三个部件是由发动机提供动力的发电机。它在汽车运转时为电气系统提供动力,并为电池充电。有了这些基本部件,汽车就可以维持它的供电了。一个名为电压调节器的装置使电量保持稳定。保险盒防止小问题变成大问题。
The first main part in the electrical system is the battery. It is used to store electricity,start and provide electricity for clock, radio and CD player and other accessary devices when the engine is closed. The second main part is start motor which is used to start the engine. The third part is the generator which is provided power by the engine. It provides power for electrical system when the vehicle rotates and charges for the battery. With these basic parts, the vehicle can maintain its charging. A so-called device of voltage regulator makes the quantity of electricity keep stable. The fuse box can prevent that small problems become big problems.
24358
sddyzyd
文章数:6952
年度积分:797
历史总积分:24358
发表于:2010/7/26 16:29:31
学习了!
809
wexial
文章数:83
历史总积分:809
发表于:2010/7/28 14:28:21
您好没有登录,不能发表回帖!
点击此处【登录】后,刷新页面即可回复。
咋回事?
46.8003
