人机界面
回帖:1个,阅读:2118次 [上一页] [1] [下一页]
cimplicity hmi 授权
113
Springal
文章数:53
年度积分:-223
历史总积分:113
发表于:2010/7/12 21:39:14
cimplicity hmi 50点授权key 序列号
6994347777
其他相关选项key
6997011111 webview 25 sessions
6998320000 webview 50 sessions
6998410000 openscada driver
6991080000 integrators toolkit
6991130000 tracker display option
6991180000 modbus rtu communications
6991300000 statistical process control
6991350000 historical data analyzer
6993120000 tracker
6993330000 recipes
6996117777 allen-bradley data highway+ communication
6996167777 server redundancy
6996177777 modbus plus communications
6996197777 multiple processor support
6996207777 applicom communications
6996247777 siemens h1-tf device communications
6996257777 allen-bradley communications
6996267777 smarteye device communications
6996277777 hmi for cnc option
6996397777 omron host link communications
6996407777 web gateway 5 users
6996417777 web gateway 10 users
6996427777 web gateway 25 users
6996437777 omron ethernet communications
6996447777 mitsubishi melsec communications
6996457777
itsubishi tcp/ip communications
6996467777 sharp tcp/ip
6996477777 square d communications
6996487777 marquee driver
6996497777 mms ethernet
6996507777 omni server development system
6996517777 omni server runtime system
6996537777 modbus tcp/ip cohmunications
6996547777 flopro/flonet communications
6996557777 johnson controls n2 communications
6996567777 seriplex i/o communications
6996577777 cimplicity pager
6996587777 siemens ti device communications
6996597777 action calendar
6996627777 toyopuc tcp/ip communications
6996637777 system sentry
6996647777 allen-bradley df1 communications
6996657777 allen-bradley rf antenna communications
6996667777 honeywell ipc620 communications
6996677777 opc server
6996687777 secs ii equipment communications
6996697777 system sentry up to 5 nodes
6996707777 system sentry up to 10 nodes
6996717777 webview single session
6996727777 webview 5 sessions
6996737777 webview 10 sessions
6996747777 thinview single user
6996807777 common machine interface[/quote]
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=119302&Name=springal
801
john_xiao_tj
文章数:1
历史总积分:801
发表于:2011/8/22 11:17:53
base serial:0004040000
system key: DA49 A5E0 B482 4E29 FF
跪求授权号码?
47.1293
