机电一体化
回帖:0个,阅读:530次 [上一页] [1] [下一页]
1104
lingshengjd
文章数:22
历史总积分:1104
发表于:2010/5/5 14:57:37
进口链条防护方法二、
Zinc – galvanic    镀锌-电镀
Parts coated in an electrolytic solution by galvanic action,Three step coating process to avoid hydrogen embrittlement,Parts passivated
部件用电解的方法涂上涂层被电镀。 三步涂层的过程避免氢脆变使局部钝化
Advantages 优点
Higher abrasive resistance       较高的耐磨强度
in comparison to  mechanical coating  Higher chemical resistance
与机械涂层相比有较高的抗腐性。
Caution areas 注意事项
De-embrittlement reduces tensile strength by 15%
氢脆变降低了15%的抗拉强度。
Nickel - galvanic plated     镀镍-电镀
Parts coated in an electrolytic solution by galvanic action. Two step coating process to improve corrosion and wear resistance.
部件用电解的方法涂上涂层并电镀。 二步涂层的过程提高了耐腐性及抗磨性
Advantages 优点
Higher mechanical and chemical resistance in comparison to Zinc
与镀锌相比较,较高的机械性能及耐腐性
Lower Toxicity    毒性小
Caution areas 注意事项
Coating process reduces tensile strength by 15%
涂层过程降低了15%的抗拉强度
Higher cost than Zinc
相比镀锌成本较高。
专业代理进口链条,进口减速机,进口电机等高端传动产品。400-000-5592
www.lsptc.ccom
15.6001
