机电一体化
回帖:0个,阅读:530次 [上一页] [1] [下一页]
1104
lingshengjd
文章数:22
历史总积分:1104
发表于:2010/5/5 14:53:06
问:Why provide protection?      为什么要对进口链条实施防护?
答:Reduce corrosion              减少腐蚀
      Various environments      各种环境
      Improve wear                   提升耐磨
      Reduced corrosion            减少腐蚀
      products in articulating components       连接部件产品
防护方式1、
Lubrication - grease and oil  润滑-油脂及油润
Lowest cost method of protecting chains against corrosion and giving good wear performance.  防止进口链条腐蚀及提高耐磨性能的最经济的方法。
优点:
Simple process        操作简单
No breaking load     不降低破断载荷
reduction                 简化
Low cost                 降低成本
注意:
Regular re-lubrication       定期润滑
Unfit for acidic and alkaline areas, or to operate under water
不适用于酸或碱性环境,或水下操作。
专业代理进口链条,进口减速机,进口电机等高端传动产品。400-000-5592
www.lsptc.ccom
31.2002
