回帖:1个,阅读:1701次 [上一页] [1] [下一页]
1909
blackc
文章数:487
历史总积分:1909
发表于:2004/9/27 8:42:00
请问一声,s7---200版中的ED,EU在梯形图中怎么表示啊?
我怎么找不到呢 ??
谢谢了
1468
syan
文章数:263
历史总积分:1468
发表于:2004/9/27 9:32:00
Instructiont--->Bitlogic-->   -|P|-
Instructiont--->Bitlogic-->   -|N|-
以下是帮助中的材料:
The Positive Transition (EU) contact allows power to flow for one scan for each off-to-on transition.The Negative Transition (ED) contact allows power to flow for one scan for each on-to-off transition.In LAD, the Positive and Negative Transition instructions are represented by contacts.In FBD, the instructions are represented by the P and N boxes.In STL, the Positive Transition contact is represented by the Edge Up instruction. Upon detection of a 0-to-1 transition in the value on the top of the stack, the top of the stack value is set to 1; otherwise, it is set to 0.In STL, the Negative Transition contact is represented by the Edge Down instruction. Upon detection of a 1-to-0 transition in the value on the top of the stack, the top of the stack value is set to 1; otherwise, it is set to 0. For runtime editing (when you edit your program in RUN mode), you must enter a parameter for the Positive Transition and Negative Transition instructions. Refer to Program Edit in RUN Mode for more information about editing in RUN mode.
尺有所短,寸有所长。
31.2002
