机器视觉
回帖:7个,阅读:3196次 [上一页] [1] [下一页]
16274
machelec 版主
文章数:7023
年度积分:-48
历史总积分:16274
发表于:2004/9/11 22:28:00
最经典的视觉欺骗
  A方块和B方块的颜色是一样的。
  它们都是r107-g107-b107。
  不信可以用photoshop提取颜色。
  现在连眼睛都不能相信了。
  的确AB的颜色是一样的,如果没有photoshop,只要把图片用画图板打开,在A、B点切下一块来观察就行了。人的眼睛果然神奇
  此主题相关图片如下:
[此贴子已经被作者于2004-9-11 22:29:16编辑过]
谓正途,崎岖当先
16274
machelec 版主
文章数:7023
年度积分:-48
历史总积分:16274
发表于:2004/9/11 22:30:00
这个图的作者
  Edward H. Adelson
  Professor of Vision Science
  Dept. of Brain and Cognitive Sciences
  and Artificial Intelligence Lab
  Massachusetts Institute of Technology
  3 Cambridge Center, NE20-444H
  Cambridge, MA 02139
  麻省理工的教授
图
谓正途,崎岖当先
16274
machelec 版主
文章数:7023
年度积分:-48
历史总积分:16274
发表于:2004/9/11 22:31:00
教授对于这个图的解释
    The visual system needs to determine the color of objects in the world. In this case the problem is to determine the gray shade of the checks on the floor. Just measuring the light coming from a surface (the luminance) is not enough: a cast shadow will dim a surface, so that a white surface in shadow may be reflecting less light than a black surface in full light. The visual system uses several tricks to determine where the shadows are and how to compensate for them, in order to determine the shade of gray "paint" that belongs to the surface.
    The first trick is based on local contrast. In shadow or not, a check that is lighter than its neighboring checks is probably lighter than average, and vice versa. In the figure, the light check in shadow is surrounded by darker checks. Thus, even though the check is physically dark, it is light when compared to its neighbors. The dark checks outside the shadow, conversely, are surrounded by lighter checks, so they look dark by comparison.
    A second trick is based on the fact that shadows often have soft edges, while paint boundaries (like the checks) often have sharp edges. The visual system tends to ignore gradual changes in light level, so that it can determine the color of the surfaces without being misled by shadows. In this figure, the shadow looks like a shadow, both because it is fuzzy and because the shadow casting object is visible.
    The "paintness" of the checks is aided by the form of the "X-junctions" formed by 4 abutting checks. This type of junction is usually a signal that all the edges should be interpreted as changes in surface color rather than in terms of shadows or lighting.
    As with many so-called illusions, this effect really demonstrates the success rather than the failure of the visual system. The visual system is not very good at being a physical light meter, but that is not its purpose. The important task is to break the image information down into meaningful components, and thereby perceive the nature of the objects in view.
谓正途,崎岖当先
1631
weiping2615
文章数:298
历史总积分:1631
发表于:2004/9/14 11:57:00
妈的,你搞个英文的谁看的懂啊
                 ☆缘分开空☆
2499
mike_CHEN
文章数:649
历史总积分:2499
发表于:2004/9/14 13:01:00
老兄,你看不懂也不要骂人吧!
E-Mail:mike.chen@163.com
16274
machelec 版主
文章数:7023
年度积分:-48
历史总积分:16274
发表于:2004/9/14 17:32:00
以下是引用mike_CHEN在2004-9-14 13:01:00的发言:
老兄,你看不懂也不要骂人吧!
没事。那是口头禅吧。有段时间我也老是这样。哈哈哈......
谓正途,崎岖当先
2248
lhdlsl
文章数:514
历史总积分:2248
发表于:2004/9/14 17:42:00
以下是引用machelec在2004-9-14 17:32:00的发言:
老兄,你看不懂也不要骂人吧!
即心即佛。。。。。。
965
keen11keen
文章数:8
历史总积分:965
发表于:2010/7/26 10:27:09
果然是高科技......
