电脑编程
回帖:14个,阅读:5180 [上一页] [1] [2] [下一页]
5364
jczwfy 版主
文章数:2259
历史总积分:5364
09工控人生征文
发表于:2009/10/21 20:26:31
禁止使用 alt-tab 或 ctrl-alt-del
private declare function enablewindow lib user32 (byval hwnd as integer, byval abool as integer) as integer
private declare function iswindowenabled lib user32 (byval hwnd as integer) as integer
private declare function getmenu lib user32 (byval hwnd as integer) as integer
private declare function findwindow lib user32 alias findwindowa (byval lpclassname as string, byval lpwindowname as string) as long
private declare function systemparametersinfo lib user32 alias systemparametersinfoa (byval uaction as long, byval uparam as long, byval lpvparam as any, byval fuwinini as long) as long
private taskbarhwnd as long
private istaskbarenabled as integer
private taskbarmenuhwnd as integer
禁止或允许使用 alt-tab
sub fasttaskswitching(benabled as boolean)
dim x as long, bdisabled as long
bdisabled = not benabled
x = systemparametersinfo(97, bdisabled, cstr(1), 0)
end sub
禁止使用ctrl-alt-del
public sub disabletaskbar()
dim ewindow as integer
taskbarhwnd = findwindow(shell_traywnd, )
if taskbarhwnd  0 then
ewindow = iswindowenabled(taskbarhwnd)
if ewindow = 1 then
istaskbarenabled = enablewindow(taskbarhwnd, 0)
end if
end if
end sub
允许使用ctrl-alt-del
public sub enabletaskbar()
if istaskbarenabled = 0 then
istaskbarenabled = enablewindow(taskbarhwnd, 1)
end if
end sub
禁止 ctrl+alt+del
声明:
const spi_screensaverrunning = 97
private declare function systemparametersinfo lib user32 alias _
systemparametersinfoa (byval uaction as long, byval uparam as long, _
使用:
禁止
dim pold as boolean
call systemparametersinfo(spi_screensaverrunning, true, pold, 0)
开启
dim pold as boolean
call systemparametersinfo(spi_screensaverrunning, false, pold, 0)
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=103666&Name=jczwfy
日本人说中日友好,中国人民笑了:你丫骗谁呢?
日本人说自己爱和平,亚洲人民笑了:说的是人话吗?
日本人说自己要维护世界和平,美国人民笑了:问你大爷没?
日本人说自己是人,全世界的狗都叫了:兄弟,做狗要厚道,不能忘本!
欢迎访问我的博客http://blog.gkong.com/blog.asp?name=jczwfy
在线PLC触摸屏问题解答加Q号2*7*5*4*7*0*0*6,加好友注明工控网
3337
ywl523
文章数:1748
历史总积分:3337
发表于:2009/10/21 21:33:45
迷糊了
1472
yuehuasheji
文章数:151
历史总积分:1472
发表于:2009/10/21 22:32:31
能实现一个什么功能
87808
ZCMY 版主
文章数:47948
年度积分:1015
历史总积分:87808
发表于:2009/10/22 9:39:36
用不来;
8264
shotgun
文章数:1453
历史总积分:8264
发表于:2009/10/23 11:44:35
此楼内容不符合板块规定,不予显示! 查看原帖内容>>
1118
by
文章数:22
历史总积分:1118
发表于:2009/12/2 9:01:55
????????????????bumingbai
3848
ZSFZSF_0
文章数:2293
历史总积分:3848
发表于:2009/12/3 12:55:52
看不懂呀
1050
HaveGood
文章数:-11
年度积分:-729
历史总积分:1050
发表于:2009/12/4 14:37:41
1950
lg0808
文章数:342
历史总积分:1950
发表于:2010/5/2 22:28:08
对牛弹琴
1442
huoxing_99
文章数:101
历史总积分:1442
发表于:2010/7/16 14:49:47
呵呵~~~
说的不太详细,其实就是用VB屏蔽一些系统功能键
许多人都没看明白楼主发的是什么
93.6006
