西门子SIEMENS
回帖:1个,阅读:834 [上一页] [1] [下一页]
4427
lhw982117910
文章数:2204
历史总积分:4427
发表于:2009/9/4 9:36:17
//Copyright (C) jiansiting 2007. All Rights Reserved. Confidential
// Block header
FUNCTION_BLOCK LED_H
TITLE =   'LED_H'
{                            // List of system attributes
//S7_tasklist:= 'OB80,OB100';  // Block is called if there is a time error and at a warm restart
S7_m_c:=      'true';        // Block can be controlled and monitored
S7_alarm_ui:= '1'            // Setting for PCS 7 message dialog ('0'=standard message dialog)
AUTHOR:   LOGGY
VERSION:      '0.01'
FAMILY:   CS2PA
KNOW_HOW_PROTECT
// Declaration Section: Block Parameters
//System attributes for parameters
S7_sampletime:='true'
S7_dynamic:='true'
S7_edit:='true'
S7_link:='true'
S7_param:='true'
S7_visible:='true'
S7_contact:='true'
S7_m_c:='true'
S7_shortcut:=''
S7_string_0:=''
S7_string_1:=''
S7_unit:=''
S7_server:='alarm_archiv'
S7_a_type:='alarm_8p'
VAR_INPUT
 EV_ID   {
          S7_visible:='false';
          S7_link:='false';
          S7_param :='false';                // Parameter cannot be set in CFC
          S7_server:='alarm_archiv';         // Message no. assigned by server
          S7_a_type:='alarm_8p'              // Block signals with ALARM_8P
          }:DWORD := 0;           // Message ID
 RUNUPCYC{
          S7_link:='false'
          } :INT := 3;           // Number of run up cycles
 REQ {S7_string_0:='No_req'; S7_string_1:='Req'}: BOOL;
 SSL_ID : WORD := W#16#0074;
 INDEX : WORD := W#16#0;
END_VAR
VAR_OUTPUT
 LENTHDR : WORD;
 N_DR{
      S7_m_c:='true'} : WORD;
 LED_ID1{
        // S7_m_c:='true';
         S7_visible :='false'} : WORD;
 LED_ID2{
        // S7_m_c:='true';
 LED_ID3{
        // S7_m_c:='true';
 LED_ID4{
       //  S7_m_c:='true';
 LED_ID5{
       //  S7_m_c:='true';
 LED_ID6{
       //  S7_m_c:='true';
 LED_ID7{
       //  S7_m_c:='true';
 LED_ID8{
       //  S7_m_c:='true';
 LED_ID9{
      //   S7_m_c:='true';
 LED_ID10{
      //   S7_m_c:='true';
 LED_ID11{
      //   S7_m_c:='true';
 LED_ID12{
      //   S7_m_c:='true';
 LED_ID13{
      //   S7_m_c:='true';
 LED_ID14{
      //   S7_m_c:='true';
 LED_ID15{
       //  S7_m_c:='true';
 LED_ID16{
      //   S7_m_c:='true';
 LED_ID17{
      //   S7_m_c:='true';
 LED_ID18{
     //    S7_m_c:='true';
 LED_ID19{
      //   S7_m_c:='true';
 LED_ID20{
      //   S7_m_c:='true';
 LED_ID21{
     //    S7_m_c:='true';
 LED_ID22{
      //   S7_m_c:='true';
 LED_ID23{
         S7_m_c:='true';
 LED_ID24{
      //   S7_m_c:='true';
 LED_ID25{
      //   S7_m_c:='true';
 LED_ID26{
      //   S7_m_c:='true';
 LED_ON
       S7_m_c:='true'
      } : DWORD;
 LED_BLINK
       S7_m_c:='true'
      } : DWORD;
 BUSY {S7_visible :='false'}: BOOL;
 CPU_FAILURE
        S7_m_c:='true'
       } : BOOL;
 CPU_FAULT
        S7_m_c:='true'
       } : BOOL;
 QMSG_ERR  {
           S7_dynamic:='true'} :  BOOL := 0;        // ALARM_8P: Error output
 MSG_STAT  {
           S7_dynamic:='true'} :  WORD := 0;        // Message: STATUS output
 MSG_ACK   {
           S7_dynamic:='true'} :  WORD := 0;        // Message: ACK_STATE output
END_VAR
VAR_IN_OUT
// Freely assignable auxiliary values of ALARM_8P
 AUX_PR01 {S7_visible := 'false'} : ANY;  // Auxiliary value 1
 AUX_PR02 {S7_visible := 'false'} : ANY;  // Auxiliary value 2
 AUX_PR03 {S7_visible := 'false'} : ANY;  // Auxiliary value 3
 AUX_PR04 {S7_visible := 'false'} : ANY;  // Auxiliary value 4
 AUX_PR05 {S7_visible := 'false'} : ANY;  // Auxiliary value 5
 AUX_PR06 {S7_visible := 'false'} : ANY;  // Auxiliary value 6
 AUX_PR07 {S7_visible := 'false'} : ANY;  // Auxiliary value 7
 AUX_PR08 {S7_visible := 'false'} : ANY;  // Auxiliary value 8
 AUX_PR09 {S7_visible := 'false'} : ANY;  // Auxiliary value 9
 AUX_PR10 {S7_visible := 'false'} : ANY;  // Auxiliary value 10
END_VAR
// Declaration Section: Static Variables
VAR
 DR : ARRAY[1..26] OF STRUCT
     CPU_LED_ID : WORD;
     LED_ON : BYTE;
     LED_BLINK : BYTE;
 END_STRUCT;
 SZL_HEADER : STRUCT
     LENTHDR : WORD;
     N_DR : WORD;
 END_STRUCT;
 sbRESTART   :BOOL := TRUE;       // Initial start memory bit
 siRUNUPCNT  :INT := 0;           // Counter for RUNUPCYC execution
// Declaration Section Multiple Instances(SFB/FB), remember to copy the FB/FC blocks into your projects manually!
 ALARM_8P_1:  ALARM_8P;   // Generation of max. 8 messages with max. 10 auxiliary values
END_VAR
// Declaration Section: Temporary Variables
VAR_TEMP
 // Start info: Structure with info for the OB that has just called the block
 TOP_SI:    STRUCT
  EV_CLASS :BYTE;
  EV_NUM   :BYTE;
  PRIORITY :BYTE;
  NUM      :BYTE;
  TYP2_3   :BYTE;
  TYP1     :BYTE;
  ZI1      :WORD;
  ZI2_3    :DWORD;
 END_STRUCT;
 // Start info: Structure with info for the last called startup OB
 START_UP_SI:  STRUCT
  EV_CLASS :BYTE;
  EV_NUM   :BYTE;
  PRIORITY :BYTE;
  NUM      :BYTE;
  TYP2_3   :BYTE;
  TYP1     :BYTE;
  ZI1      :WORD;
  ZI2_3    :DWORD;
 END_STRUCT;
 DUMMY  :INT;                     // Auxiliary variable
 ALARM_OUT :BOOL;
 TEMP1 : INT;
 TEMP2,TEMP3,TEMP4,TEMP5 : DWORD;
 TEMP6 : WORD;
END_VAR
// Code Section
// Dependence on Calling OB
// Read out start info with SFC6 (RD_SINFO)
 DUMMY := RD_SINFO (TOP_SI := TOP_SI, START_UP_SI := START_UP_SI);
IF sbRESTART THEN
 // Initial start
 TOP_SI.NUM := 100;         // Execute initial start as warm restart
 sbRESTART := FALSE;         // Reset initial start
END_IF;
// In which OB was the block called ?
CASE WORD_TO_INT(BYTE_TO_WORD(TOP_SI.NUM)) OF
// Handling Error OBs
// OB80: time error
   80:
// Startup
// OB100: Warm restart
   100:
   siRUNUPCNT := RUNUPCYC;  // Save RUNUPCYC value
ELSE
// Technological Section
//get the LED status from controller
   TEMP1:=RDSYSST(REQ :=REQ  // IN: BOOL
           ,SZL_ID :=SSL_ID  // IN: WORD
           ,INDEX :=INDEX  // IN: WORD
           ,BUSY :=BUSY  // OUT: BOOL
           ,SZL_HEADER :=SZL_HEADER  // OUT: STRUCT
           ,DR :=DR  // OUT: ANY
           ); // INT
   LENTHDR := SZL_HEADER.LENTHDR;
   N_DR := SZL_HEADER.N_DR;
   IF N_DR=W#16#D THEN
       CPU_FAILURE :=TRUE;
   ELSE
       CPU_FAILURE :=FALSE;
   END_IF;
//filter the data and construct the data for displaying in OS
   TEMP3 :=BYTE_TO_DWORD(DR[1].LED_ON);
   TEMP4 :=BYTE_TO_DWORD(DR[1].LED_BLINK)AND DW#16#1;
   FOR TEMP1:= 1 TO (WORD_TO_INT(SZL_HEADER.N_DR)-1) BY 1 DO
   // Statement Section
    TEMP2 :=ROL(IN:=BYTE_TO_DWORD(DR[TEMP1+1].LED_ON), N :=TEMP1);
    TEMP3 :=TEMP3 OR TEMP2;
    TEMP5 :=ROL(IN:=BYTE_TO_DWORD(DR[TEMP1+1].LED_BLINK), N :=TEMP1) AND ROL(IN:=DW#16#1, N :=TEMP1);
    TEMP4 :=TEMP4 OR TEMP5;
   END_FOR;
   TEMP6 :=DR[1].CPU_LED_ID AND W#16#FF00;
   IF TEMP6=W#16#F900 THEN
       TEMP2 :=ROR(IN:=TEMP3 AND DW#16#03FFD000, N :=13);
       TEMP5 :=ROL(IN:=TEMP3 AND DW#16#00001FFF, N :=13);
       TEMP3 :=TEMP2 OR TEMP5;
       TEMP2 :=ROR(IN:=TEMP4 AND DW#16#03FFD000, N :=13);
       TEMP5 :=ROL(IN:=TEMP4 AND DW#16#00001FFF, N :=13);
       TEMP4 :=TEMP2 OR TEMP5;
   ELSE
   END_IF;
   TEMP2 :=TEMP3 AND DW#16#001C60E3;
   IF TEMP2 <> DW#16#0 THEN
       CPU_FAULT :=TRUE;
   ELSE
       CPU_FAULT :=FALSE;
   END_IF;
   LED_ID1 := DR[1].CPU_LED_ID;
   LED_ID2 := DR[2].CPU_LED_ID;
   LED_ID3 := DR[3].CPU_LED_ID;
   LED_ID4 := DR[4].CPU_LED_ID;
   LED_ID5 := DR[5].CPU_LED_ID;
   LED_ID6 := DR[6].CPU_LED_ID;
   LED_ID7 := DR[7].CPU_LED_ID;
   LED_ID8 := DR[8].CPU_LED_ID;
   LED_ID9 := DR[9].CPU_LED_ID;
   LED_ID10 := DR[10].CPU_LED_ID;
   LED_ID11 := DR[11].CPU_LED_ID;
   LED_ID12 := DR[12].CPU_LED_ID;
   LED_ID13 := DR[13].CPU_LED_ID;
   LED_ID14 := DR[14].CPU_LED_ID;
   LED_ID15 := DR[15].CPU_LED_ID;
   LED_ID16 := DR[16].CPU_LED_ID;
   LED_ID17 := DR[17].CPU_LED_ID;
   LED_ID18 := DR[18].CPU_LED_ID;
   LED_ID19 := DR[19].CPU_LED_ID;
   LED_ID20 := DR[20].CPU_LED_ID;
   LED_ID21 := DR[21].CPU_LED_ID;
   LED_ID22 := DR[22].CPU_LED_ID;
   LED_ID23 := DR[23].CPU_LED_ID;
   LED_ID24 := DR[24].CPU_LED_ID;
   LED_ID25 := DR[25].CPU_LED_ID;
   LED_ID26 := DR[26].CPU_LED_ID;
   LED_ON :=TEMP3;
   LED_BLINK :=TEMP4;
// Message suppression during the startup
 IF siRUNUPCNT = 0               // RUNUPCYC cycle already elapsed ?
 THEN
   ALARM_OUT :=TRUE;
 ELSE
  siRUNUPCNT := siRUNUPCNT - 1;
 END_IF;
END_CASE;
// Messages with ALARM_8P
// STRING variables must not be linked to ALARM8_P as auxiliary values
// so transfer in array of bytes
ALARM_8P_1
    (EN_R := TRUE,    // Update output ACK_STATE
     ID := 16#EEEE,         // Data channel for messages (always 16#EEEE)
     EV_ID:= EV_ID,         // Message number > 0
     SIG_1:= ALARM_OUT AND CPU_FAILURE,                        // Signal 1 to be monitored
     SIG_2:= ALARM_OUT AND CPU_FAULT,                        // Signal 2 to be monitored
     SIG_3:= 0,                        // Signal 3 to be monitored
     SIG_4:= 0,                        // Signal 4 to be monitored
     SIG_5:= 0,                        // Signal 5 to be monitored
     SIG_6:= 0,                        // Signal 6 to be monitored
     SIG_7:= 0,                        // Signal 7 to be monitored
     SIG_8:= 0,                        // Signal 8 to be monitored
     SD_1 := AUX_PR01,      // Auxiliary value 1
     SD_2 := AUX_PR02,     // Auxiliary value 2
     SD_3 := AUX_PR03,       // Auxiliary value 3
     SD_4 := AUX_PR04,       // Auxiliary value 4
     SD_5 := AUX_PR05,      // Auxiliary value 5
     SD_6 := AUX_PR06,      // Auxiliary value 6
     SD_7 := AUX_PR07,      // Auxiliary value 7
     SD_8 := AUX_PR08,      // Auxiliary value 8
     SD_9 := AUX_PR09,      // Auxiliary value 9
     SD_10:= AUX_PR10);     // Auxiliary value 10
   QMSG_ERR := ALARM_8P_1.ERROR;      // ERROR status parameter
   MSG_STAT := ALARM_8P_1.STATUS;     // STATUS status parameter
   MSG_ACK := ALARM_8P_1.ACK_STATE;   // Current OS confirmation status
END_FUNCTION_BLOCK
rocky
1010
yzdatou
文章数:31
历史总积分:1010
发表于:2009/9/17 15:22:03
剑思庭写的
不错不错
pcs7的代码风格
水平高<>收入高
水平高<>职位高
所以做人要低调
