传感器论坛
回帖:6个,阅读:1288次 [上一页] [1] [下一页]
PT100热电阻分度表
964
kmaway
文章数:3
历史总积分:964
发表于:2009/8/30 20:38:55
工控朋友大家好!以下是pt100热电阻分度表。帮助有需要的朋友,我乐意!
pt100型热电阻分度表
org 3000h
;pt100 r_t tablt ,-101~267c
pt100_tablt:
dw 5987,6025,6066,6106,6147,6187,6228,6268,6309,6349,6390,6430   ;-101~-90c
dw 6470,6511,6551,6591,6631,6672,6712,6752,6792,6833                   ;-89~ -80c
dw 6873,6913,6953,6993,7033,7073,7113,7153,7193,7233                   ;-79~-70c
dw 7273,7313,7353,7393,7433,7473,7513,7553,7593,7633                   ;-69~-60c
dw 7673,7713,7752,7792,7832,7872,7911,7951,7991,8031                   ;-59~-50c
dw 8070,8110,8150,8189,8229,8269,8308,8348,8388,8427                   ;-49~-40c
dw 8467,8506,8546,8585,8625,8664,8704,8743,8783,8822                   ;-39~-30c
dw 8862,8901,8940,8980,9019,9059,9098,9137,9177,9216                   ;-29~-20c
dw 9255,9295,9334,9373,9412,9452,9491,9530,9569,9609                   ;-19~-10c
dw 9648,9687,9726,9765,9804,9844,9883,9922,9961,10000                 ;-9~0c
dw 10039,10078,10117,10156,10195,10234,10273,10312,10351,10390   ;1~10c
dw 10429,10468,10507,10546,10585,10624,10663,10702,10740,10779   ;11~20c
dw 10818,10857,10896,10935,10973,11012,11051,11090,11128,11167   ;21~30c
dw 11206,11245,11283,11322,11361,11399,11438,11477,11515,11554   ;31~40c
dw 11593,11631,11670,11708,11747,11785,11824,11862,11901,11940   ;41~50c
dw 11978,12016,12055,12093,12132,12170,12209,12247,12286,12324   ;51~60c
dw 12362,12401,12439,12477,12516,12554,12592,12631,12669,12707   ;61~70c
dw 12745,12784,12822,12860,12898,12937,12975,13013,13051,13089   ;71~80c
dw 13127,13166,13204,13242,13280,13318,13356,13394,13432,13470   ;81~90c
dw 13508,13546,13584,13622,13660,13698,13736,13774,13812,13850   ;91~100c
dw 13888,13926,13964,14002,14039,14077,14115,14153,14191,14229   ;101~110c
dw 14266,14304,14342,14380,14417,14455,14493,14531,14568,14606   ;111~120c
dw 14644,14681,14719,14757,14794,14832,14870,14907,14945,14982   ;121~130c
dw 15020,15057,15095,15133,15170,15208,15245,15283,15320,15358   ;131~140c
dw 15395,15432,15470,15507,15545,15582,15629,15657,15694,15731   ;141~150c
dw 15769,15806,15843,15881,15918,15955,15993,16030,16067,16104   ;151~160c
dw 16142,16179,16216,16253,16290,16327,16365,16402,16439,16476   ;161~170c
dw 16513,16550,16587,16624,16661,16698,16735,16772,16809,16846   ;171~180c
dw 16883,16920,16957,16994,17031,17068,17105,17142,17179,17216   ;181~190c
dw 17253,17290,17326,17363,17400,17437,17474,17510,17547,17584   ;191~200c
dw 17621,17657,17694,17731,17768,17804,17841,17878,17914,17951   ;201~210c
dw 17988,18024,18061,18097,18134,18171,18207,18244,18280,18317   ;211~220c
dw 18353,18390,18426,18463,18499,18536,18572,18609,18645,18682   ;221~230c
dw 18718,18754,18791,18827,18863,18900,18936,18972,19009,19045   ;231~240c
dw 19081,19118,19154,19190,19226,19263,19299,19335,19371,19407   ;241~250c
dw 19444,19480,19516,19552,19588,19624,19660,19696,19733,19769   ;251~260c
dw 19805,19841,19877,19913,19949,19985,20021                                ;261~267c
以上数据可以直接粘贴到你的汇编中。
大家有空的话,请关注一下博客中的“cba8000温湿度控制器”。
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=98896&Name=kmaway
9216
paul1088
文章数:24
历史总积分:9216
发表于:2009/8/31 8:36:09
谢谢!辛苦了!!
3562
chengjun77
文章数:2027
历史总积分:3562
发表于:2009/8/31 11:31:46
收藏了
匿名用户
文章数:N/A
年度积分:0
历史总积分:0
发表于:2012/1/19 21:39:29
该用户被锁定,回复内容不予显示!
789
you3412
文章数:16
历史总积分:789
发表于:2012/1/27 14:38:55
此楼内容不符合板块规定,不予显示! 查看原帖内容>>
789
you3412
文章数:16
历史总积分:789
发表于:2012/2/4 16:40:01
96.0564
