西门子SIEMENS
回帖:1个,阅读:3028次 [上一页] [1] [下一页]
1025
njcx
文章数:39
历史总积分:1025
发表于:2009/5/7 11:53:23
请各位大侠帮帮我,我在step 7 V5.1软件中向step7-300 CPU312C中下载程序时,弹出信息:“Unable to reach the module CPU 312C by means of the online interface that is set.”不知是何原因?我是通过CP5611(MPI)同CPU321C的MPI口通信的,CP5611(MPI)的设置如下:勾选了PG/PC is the only master on the bus;Address:0;Timeout:10s;Transmission Rate:187.5 Kbps;Highest Node Address:31;另外在线连接是可以的,怎么回事呢?请各位帮帮我,谢谢!
1027
xerk0727
文章数:15
历史总积分:1027
发表于:2009/5/7 15:55:20
dfgdfgdgg
3156.3058
