串口通信
回帖:0个,阅读:1265次 [上一页] [1] [下一页]
求教-急!急!急
900
qianqian1234
文章数:1
历史总积分:900
发表于:2009/4/22 18:23:48
Dim x1, k1, k2
Dim p11, p22 '定义变量
Dim aa() As Byte '定义数组
Private Sub Timer1_Timer()
MSComm1.PortOpen = True
ReDim aa(0 To 5)
k1 = 0
If k1 = 0 Then MSComm1.Output = "1" + Chr(10) + Chr(13)
Do While MSComm1.InBufferCount = 0
Loop
aa = MSComm1.Input
If aa(0) > 64 Then GoTo xxx:
k2 = Int(aa(0) * 255 + aa(1) * 1)
Select Case k2
Case 1
p11 = Int(aa(2) * 255 + aa(3) * 1)
p22 = Int(aa(4) * 255 + aa(5) * 1)
Case Else
End Select
k1 = k1 + 1
If k1 > 2 Then k1 = 0
xxx:
MSComm1.PortOpen = False
End Sub
如何让p11和p22显示浮点数?
请高手帮帮忙,回答一下!!!
谢谢!
31.2002
