欧姆龙OMRON
回帖:2个,阅读:1218 [上一页] [1] [下一页]
940
muzeli
文章数:10
历史总积分:940
发表于:2009/3/31 20:31:59
请问CQM1H,CPU单元内置输入主要是输入什么的?本人新手请指教。先谢了
[此贴子已经被jint于2009-4-1 8:36:08编辑过]
15179
风之力 版主
文章数:6442
历史总积分:15179
发表于:2009/3/31 22:38:19
建议看书。
OMRON那么一本厚书,里面有答案。
5681
心情 版主
文章数:1633
历史总积分:5681
09工控人生征文
发表于:2009/3/31 23:31:11
Inner Boards
High-speed counter board:  4 pulse inputs (high speed counter) at 500kHz max 4 external outputs CQM1H-CTB41
Pulse I/O board:  2 Pulse inputs, Single phase 50Khz, Differential phase: 25kHz CQM1H-PLB21
Absolute encoder Interface board:2 absolute encoder (gray code binary) inputs (4kHz)       CQM1H-ABB21
Analog setting board: 4 analog settings      CQM1H-AVB41
Analog I/O board: 4 analog inputs: 0 to 5v, 0 to20mA, -10 to +10V
                        2 analog outputs: 0 to 20mA, -10 to +10V             CQM1H-MAB42
Serial communications board: One RS-232C port and one RS-422A/485 port CQM1H-SCB41
46.8003
