回帖:1个,阅读:1120 [上一页] [1] [下一页]
1547
netcookie
文章数:108
历史总积分:1547
发表于:2009/1/7 13:38:40
[size=4][face=黑体]  工程实践发现,好多人喜欢用wincc的name connect连接方法,对于单卡来讲,可以用C脚本实现即可;
#include "apdefap.h"
int gscAction( void )
#define TAG_0 "@aa@AlternateConnectionAddress"
#define TAG_1 "@aa@ConnectionEstablishMode"
#define TAG_2 "@aa@ConnectionState"
#define TAG_3 "@aa@ForceConnectionAddress"
#pragma code("msrtcli.dll")
#include "msrtapi.h"
#pragma code()
#pragma code( "kernel32.dll" )
VOID GetLocalTime(LPSYSTEMTIME lpSystemTime);
#pragma code()
static int Mld_Main = 0;
static int Mld_Res = 0;
DWORD ServiceID = 0;
static BOOL InitFirst = TRUE;
static MSG_RTCREATE_STRUCT  MsgCreate;
CMN_ERROR Error;
if ( InitFirst == TRUE )
{ memset( &MsgCreate, 0, sizeof (MSG_RTCREATE_STRUCT) );
MsgCreate.dwMsgState = MSG_STATE_COME;
MsgCreate.wTextValueUsed = 1;
sprintf( MsgCreate.mtTextValue[0].szText, "sg" );
SetTagChar( TAG_0, "H1,08 00 06 71 88 06,,0,3,02" );
InitFirst = FALSE;
if (  GetTagDWordWait( TAG_1 ) == 0  )
Mld_Main = 0;
Mld_Res = 0;
return 0;
else
GetLocalTime( &MsgCreate.stMsgTime );
MSRTStartMsgService ( &ServiceID, NULL, NULL, MSG_NOTIFY_MASK_ARCHIV, NULL, &Error );
if (  GetTagDWordWait( TAG_2 ) == 0  )
    if (  GetTagDWordWait( TAG_3 ) == 0  )
if ( Mld_Main == 0 )
MsgCreate.dwMsgNr = 1012222;
MSRTCreateMsg( ServiceID, &MsgCreate, &Error );
Mld_Main = 1;
SetTagBit("10KA",1);
else
if ( Mld_Res == 0 )
MsgCreate.dwMsgNr = 1012224;
Mld_Res = 1;
  SetTagDWord( TAG_3, 1 );
else
SetTagDWord( TAG_3, 0 );
else
if (  ( Mld_Main != 0 )  ||  ( Mld_Res != 0 )  )
Mld_Main = 0;
Mld_Res = 0;
MsgCreate.dwMsgNr = 1012223;
else
MsgCreate.dwMsgNr = 1012225;
if ( ServiceID != 0 )
MSRTStopMsgService ( ServiceID, &Error );
return 1;
[/face][/size]
4427
lhw982117910
文章数:2204
历史总积分:4427
发表于:2009/1/7 13:43:44
很高深,现在才开始学习S7-300PLC,400的属于大型系统的,等以后再学习。
rocky
46.8003
