三菱Mitsubishi
回帖:4个,阅读:2276 [上一页] [1] [下一页]
PLSY指令简述
2236
gk528
文章数:482
历史总积分:2236
发表于:2008/11/2 3:34:00
PLSY指令没有加减速控制,驱动后后立即以指定的脉冲频率输出脉冲
在输出过程中改变脉冲频率,其输出脉冲频率立刻改变(调速很方便);
在输出过程中改变输出脉冲数,驱动断开再一次闭合后才按新的脉冲数输出;
更多指令:
三菱FX系列PLC的基本顺控指令说明(一):
http://www.gk528.com/gplc/2008/20080928000352.asp
三菱FX系列PLC的基本顺控指令说明(二):
http://www.gk528.com/gplc/2008/20080929232852.asp
三菱FX系列PLC的基本顺控指令说明(三):
http://www.gk528.com/gplc/2008/20081002003843.asp
三菱FX系列PLC的基本顺控指令说明(四)定时器:
http://www.gk528.com/gplc/2008/20081003013817.asp
三菱FX系列PLC的基本顺控指令说明(四)计数器:
http://www.gk528.com/gplc/2008/20081003032152.asp
中断程序实例:
http://www.gk528.com/gplc/2008/20081007113543.asp
监视定时器WDT:
http://www.gk528.com/gplc/2008/20081007131908.asp
条件跳转CJ:
http://www.gk528.com/gplc/2008/20081008173414.asp
比较指令CMP与区域比较指令ZCP:
http://www.gk528.com/gplc/2008/10/20081008194512.asp
传送指令M0V:
http://www.gk528.com/gplc/2008/10/20081008203342.asp
成批传送BMOV:
http://www.gk528.com/gplc/2008/10/20081009130708.asp
反相转送CML:
http://www.gk528.com/gplc/2008/10/20081009200343.asp
多点传送指令FMOV:
http://www.gk528.com/gplc/2008/10/20081009201947.asp
交换指令XCH:
http://www.gk528.com/gplc/2008/10/20081009202949.asp
绝对位置控制指令DRVA:
http://www.gk528.com/gplc/2008/10/20081014234424.asp
相对位置控制指令DRVI:
http://www.gk528.com/gplc/2008/10/20081015155851.asp
触点比较指令:
http://www.gk528.com/gplc/2008/10/20081015204017.asp
可变速脉冲输出指令PLSV:
http://www.gk528.com/gplc/2008/10/20081015205615.asp
原点回归指令ZRN:
http://www.gk528.com/gplc/2008/10/20081016175709.asp
位传送指令SMOV:
http://www.gk528.com/gplc/2008/10/20081017114018.asp
BCD交换指令:
http://www.gk528.com/gplc/2008/10/20081017235153.asp
BIN交换指令:
http://www.gk528.com/gplc/2008/10/20081018001228.asp
加(减)法运算指令ADD(SUB):
http://www.gk528.com/gplc/2008/10/20081018175208.asp
乘(除)法运算指令MUL(DIV):
http://www.gk528.com/gplc/2008/10/20081018184526.asp
增加指令INC与减少指令DEC:
http://www.gk528.com/gplc/2008/10/20081018190227.asp
逻辑与WAND,逻辑或WOR,逻辑异或WXOR指令:
http://www.gk528.com/gplc/2008/10/20081018191458.asp
求补指令NEG:
http://www.gk528.com/gplc/2008/10/20081018193639.asp
右回转ROR与左回转ROL指令:
http://www.gk528.com/gplc/2008/10/20081018195938.asp
位右移SFTR与位左移SFTL指令:
http://www.gk528.com/gplc/2008/10/20081018204827.asp
字右移WSFR与字左移WSFL指令:
http://www.gk528.com/gplc/2008/10/20081021203225.asp
移位写入SFWR与移位读出SFRD指令:
http://www.gk528.com/gplc/2008/10/20081023190436.asp
全部复位ZRST指令:
http://www.gk528.com/gplc/2008/10/20081023202317.asp
比较指令DECO:
http://www.gk528.com/gplc/2008/10/20081023210117.asp
编码指令ENCO:
http://www.gk528.com/gplc/2008/10/20081024073659.asp
ON位数指令SUM:
http://www.gk528.com/gplc/2008/10/20081025222119.asp
ON位数判断指令BON:
http://www.gk528.com/gplc/2008/10/20081025224355.asp
求平均值指令MEAN:
http://www.gk528.com/gplc/2008/10/20081025230431.asp
BIN开方运算指令SQR:
http://www.gk528.com/gplc/2008/10/20081026180445.asp
BIN整数到2进制浮点数转换指令FLT:
http://www.gk528.com/gplc/2008/10/20081026184602.asp
输入输出刷新指令REF:
http://www.gk528.com/gplc/2008/10/20081027014612.asp
输入滤波调整指令REFF:
http://www.gk528.com/gplc/2008/10/20081027142128.asp
矩阵输入指令MTR:
http://www.gk528.com/gplc/2008/10/20081027151835.asp
比较置位指令DHSCS和复位指令DHSCR(高速计数器用):
http://www.gk528.com/gplc/2008/10/20081027173150.asp
区间比较指令DHSZ(高速计数器用):
http://www.gk528.com/gplc/2008/10/20081027181037.asp
脉冲密度指令SPD:
http://www.gk528.com/gplc/2008/10/20081027235833.asp
脉冲输出指令PLSY:
http://www.gk528.com/gplc/2008/10/20081028093901.asp
脉宽调制指令PWM:
http://www.gk528.com/gplc/2008/10/20081028104322.asp
带加减速脉冲输出指令PLSR:
http://www.gk528.com/gplc/2008/10/20081028183917.asp
数据查找指令SER:
http://www.gk528.com/gplc/2008/10/20081028211330.asp
绝对方式凸轮控制指令ABSD:
http://www.gk528.com/gplc/2008/10/20081031140111.asp
增量方式凸轮控制指令INCD:
http://www.gk528.com/gplc/2008/10/20081031163628.asp
示教定时器TTMR指令:
http://www.gk528.com/gplc/2008/11/20081101041926.asp
特殊定时器STMR指令:
http://www.gk528.com/gplc/2008/11/20081101195412.asp
交替输出指令ALT:
http://www.gk528.com/gplc/2008/11/20081101200721.asp
斜坡指令RAMP:
http://www.gk528.com/gplc/2008/11/20081101213253.asp
数据排序指令SORT:
http://www.gk528.com/gplc/2008/11/20081102025411.asp
[此贴子已经被作者于2008-11-2 3:51:13编辑过]
528工控科技 串口 以太网 通讯 MODBUS
4139
sankyo_feng
文章数:730
历史总积分:4139
发表于:2008/11/2 10:04:00
顶一下!
38960
fumz78 版主
文章数:17153
年度积分:59
历史总积分:38960
2017春节活动(二)
2016国庆活动(二)
晒晒工控小礼品
08年最佳博客奖
发表于:2008/11/2 15:29:00
这个指令还有一个好用的功能就是把脉冲数设成0
条件成立时可以一直运行下去
三菱 PLC、触摸屏、伺服电机、变频器、数控系统
   深圳       fumz78@163.com
6593
sqhuang
文章数:1047
历史总积分:6593
发表于:2008/11/26 12:50:00
学习了,以前没用到这指令,学学也好
843
deletec
文章数:24
历史总积分:843
发表于:2010/9/11 22:25:40
陈年好贴就这样被埋没了,可惜!!!!!!!!
泥萝卜,擦一段吃一段,只盯着故障部分苦想,不知道全盘都有牵连的。
