单片机论坛
回帖:0个,阅读:1057 [上一页] [1] [下一页]
单片机c程序02
1031
zhaosiyun
文章数:8
历史总积分:1031
发表于:2008/9/11 22:32:00
void lock(unsigned char cpu) {
   unsigned char i;
   switch (cpu) {
   case 1:    //89c51
   case 2:
       //lock 1
       rst=p26=p36=p27=p37=1;nop();
       vpp=1;
       nop();
       ale=0;
   //    for (i=0;iflash) {disp=0;led=!led;}
//ht1380实时时钟驱动程序
sbit clock_dat=p0^1;
sbit clock_clk=p0^2;
sbit clock_rst=p0^3;
sbit a0=acc^0;
sbit a1=acc^1;
sbit a2=acc^2;
sbit a3=acc^3;
sbit a4=acc^4;
sbit a5=acc^5;
sbit a6=acc^6;
sbit a7=acc^7;
void clock_out(unsigned char dd) {
   acc=dd;
   clock_dat=a0;clock_clk=1;clock_clk=0;
   clock_dat=a1;clock_clk=1;clock_clk=0;
   clock_dat=a2;clock_clk=1;clock_clk=0;
   clock_dat=a3;clock_clk=1;clock_clk=0;
   clock_dat=a4;clock_clk=1;clock_clk=0;
   clock_dat=a5;clock_clk=1;clock_clk=0;
   clock_dat=a6;clock_clk=1;clock_clk=0;
   clock_dat=a7;clock_clk=1;clock_clk=0;
unsigned char clock_in(void) {
   clock_dat=1;
   a0=clock_dat;
   clock_clk=1;clock_clk=0;a1=clock_dat;
   clock_clk=1;clock_clk=0;a2=clock_dat;
   clock_clk=1;clock_clk=0;a3=clock_dat;
   clock_clk=1;clock_clk=0;a4=clock_dat;
   clock_clk=1;clock_clk=0;a5=clock_dat;
   clock_clk=1;clock_clk=0;a6=clock_dat;
   clock_clk=1;clock_clk=0;a7=clock_dat;
   return(acc);
unsigned char read_clock(unsigned char ord) {
   unsigned char dd=0;
   clock_clk=0;
   clock_rst=0;
   clock_rst=1;
   clock_out(ord);
   dd=clock_in();
   clock_rst=0;
   clock_clk=1;
   return(dd);
void write_clock(unsigned char ord,unsigned char dd) {
   clock_clk=0;
   clock_rst=0;
   clock_rst=1;
   clock_out(ord);
   clock_out(dd);
   clock_rst=0;
   clock_clk=1;
/*单个汉字库字摸提取程序,tc2.0编译*/
#include stdio.h
#include dos.h
#include process.h
#include string.h
void main(void) {
   long int num_bytes,qm,wm;
   unsigned char d,i,j,k,a[132],b[132];
   unsigned char * data;
   unsigned char * hz;
   static unsigned  char dd[103];
   file *fp;
此篇文章从博客转发
原文地址: Http://blog.gkong.com/more.asp?id=61989&Name=zhaosiyun
31.2002
