单片机论坛
回帖:1个,阅读:1711 [上一页] [1] [下一页]
1005
aoyoutian
文章数:1
历史总积分:1005
发表于:2008/7/2 11:04:00
用的MSP430的单片机,cs5532能正常读写寄存器,复位也正常
就是读不出转换结果,不过32位结果后8位标志位可以显示通道号...
void CS5532_Init()
   unsigned short i;
   P3OUT &= 0xFE;     CS使能
   Delay();
   //CS5532初始化
   for(i=0;i<15;i++)
       cs5532_write(0xFF);
   cs5532_write(0xFE);
   cs5532_write(0x03);
   cs5532_write(0x20);
   cs5532_write(0x00);
   cs5532_write(0x00);
   cs5532_write(0x00);
   //等待复位完成
   cs5532_write(0x0b);
   test=0;
   test|=cs5532_read();
   test<<=8;
   test<<=8;
   test<<=8;
   //CS5532写选择通道寄存器1
   cs5532_write(0x05);
   cs5532_write(0x02);       //选择物理通道1,增益1,7.5hz,双极性,setup1
   cs5532_write(0x08);
   cs5532_write(0x42);        //选择物理通道2,增益1,7.5hz,双极性, setup2
   cs5532_write(0x08);
   //CS5532写配置寄存器,初始化电压参考模型
   cs5532_write(0x03);
   cs5532_write(0x02);                         //参考电压 1V<=Vref<=VA+
   cs5532_write(0x00);
   cs5532_write(0x00);
   cs5532_write(0x00);
   //校准
   cs5532_write(0x81);                          //setup1(通道1)自偏移校准
   Delay1();
   cs5532_write(0x89);                          //setup2(通道2)自偏移校准
   Delay1();
void CS5532_AD()
   unsigned short i;
   Delay();
   for(i=0;i<8;i++)
       Ua_temp[i]=0;
   //AD转换
   cs5532_write(0x80);
   Delay1();
   cs5532_write(0x0c);
   Delay();
   Ua_temp[0] |= cs5532_read();
   Delay();
   Ua_temp[1] |= cs5532_read();
   Delay();
   Ua_temp[2] |= cs5532_read();
   Delay();
   Ua_temp[3] |= cs5532_read();                   //状态字节(溢出位和通道指示)
   cs5532_write(0x88);                                 //通道2 setup2
   Delay1();
   cs5532_write(0x0c);
   Delay();
   Ua_temp[4] |= cs5532_read();
   Delay();
   Ua_temp[5] |= cs5532_read();
   Delay();
   Ua_temp[6] |= cs5532_read();
   Delay();
   Ua_temp[7] |= cs5532_read();                   //状态字节(溢出位和通道指示)
   Delay();
void cs5532_write(unsigned char data)
   unsigned char i;
   for(i=0;i<8;i++)
       P3OUT &= 0xF7;                //SCLK=0
       if((data & 0x80) == 0x80)
           P3OUT |= 0x02;            //SDI=1
       else
           P3OUT &= 0xFD;          //SDI=0
       P3OUT |= 0x08;              //SCLK=1
       data<<=1;
       Delay2();
unsigned short cs5532_read(void)
   unsigned char i;
   unsigned short data=0;
   for(i=0;i<8;i++)
       P3OUT &= 0xF7;
       if((P3IN & 0x04) == 0x04)        //SDO读数
           data |= 0x01;
       else
           data &= 0xFE;
       if(i<7)
           data<<=1;
       P3OUT |= 0x08;
       Delay2();
   return(data);
1005
siwei888
文章数:1
历史总积分:1005
发表于:2008/7/17 12:00:00
解决了吗?我也遇到此问题了
