工控英语角
回帖:0个,阅读:1629次 [上一页] [1] [下一页]
1140
chenfe3211
文章数:57
历史总积分:1140
发表于:2007/11/6 14:21:00
大拉机:rod breakdown machine
中拉机:intermediate wire drawing machine
小拉机:fine wire drawing machine
细拉机:very fine wire drawing machine
微拉机:super fine wire drawing machine
多模拉线机:multi-draft wire drawing machine
绞线机: wire-stranding machine
放线机:pay-off machine
放线盘:supply bobbin
放线架:supply frame
放线装置:take-off stand
放线牵引轮:supply capstan
退火机:annealing machine
退火线径:annealing wire diameter
最高退火速度:Max annealing wire speed
最大退火电源:Max annealing current
最大退火电压:Max annealing vollage
退火轮名义直径:diameter of annealing wheel
退火形式:annealing way
进线直径: inler diameter
出线直径: outlet diameter
最高机械速度:Max mechanical speed
拉丝模:Number of drawing die
拉丝鼓轮直径:diameter of  blast wheel
电机功率:motor
出线回转模转速:rotate speed of outlet helicoid die
31.2002
