电脑编程
回帖:6个,阅读:3439次 [上一页] [1] [下一页]
1048
ZHANGYL1981
文章数:12
历史总积分:1048
发表于:2007/10/24 17:44:00
我用VB编的程序与欧姆龙的PLC CPM1A通信,目的读取DM存储区的数据,我用了6个TIMER时钟,但是在我运行时总是出错提示:实时错误13 ,类型不匹配。我怀疑是这6个时钟的循环时间设置的问题,有没有高手告诉我问题在哪啊!我的邮箱zhangyongliangaaa@126.com
程序如下:
Dim tim As Integer
Private Sub Command1_Click()
Dim outstring As String
MSComm1.InBufferCount = 0
   outstring = "@" + "00" + "SC" + "03"
   fcdd$ = XORR(outstring)
   outstring = outstring + fcdd$ + "*" + Chr$(13)
   MSComm1.Output = outstring
   Time_out = tim
    Do
      If tim > (Time_out + 1) Then
        ERROR_COM = True
      Else
        ERROR_COM = False
      End If
      DoEvents
    Loop Until ((MSComm1.InBufferCount >= 11) Or (ERROR_COM = True))
     Instring = MSComm1.Input
     endcode = Mid(Instring, 6, 2)
     Call ErrMessage(endcode)
End Sub
Private Sub Command2_Click()
   outstring = "@" + "00" + "SC" + "00"
   Time_out = tim
    Do
        ERROR_COM = True
      Else
        ERROR_COM = False
      End If
      DoEvents
End Sub
Private Sub Command3_Click()
   outstring = "@" + "00" + "WD" + "0012" + Text2.Text
   Time_out = tim
    Do
        ERROR_COM = True
      Else
        ERROR_COM = False
      End If
      DoEvents
End Sub
Private Sub Command4_Click()
   outstring = "@" + "00" + "WD" + "0036" + (Text2.Text / 0.099695)
   Time_out = tim
    Do
        ERROR_COM = True
      Else
        ERROR_COM = False
      End If
      DoEvents
End Sub
Private Sub Command5_Click()
End
End Sub
Private Sub Form_Load()         '初始化
  Caption = "Form1"
  ClientHeight = 4095
  ClientLeft = 60
  ClientTop = 345
  ClientWidth = 4275
  LinkTopic = "Form1"
  ScaleHeight = 4095
  ScaleWidth = 4275
tim = 0
 Call INIT_comm
End Sub
Public Sub INIT_comm()
 'Buffer to hold input string
 Dim Instring, outstring As String
   MSComm1.CommPort = 1   'Use COM1.
   MSComm1.Settings = "9600,e,7,2"  '9600 baud, e parity, 7 data, and 2 stop bit.
   MSComm1.InputLen = 0   'Tell the control to read entire buffer when Input
   MSComm1.PortOpen = True   'Open the port.
End Sub
Private Sub Timer1_Timer()
 MSComm1.InBufferCount = 0 'clear off  inbuffer
   outstring = "@" + "00" + "RD" + "0010" + "0011"
   Time_out = tim
  '判断通讯错误
   Do
       ERROR_COM = True
     Else
       ERROR_COM = False
     End If
       DoEvents
   Loop Until ((MSComm1.InBufferCount >= 11 + 4 * Lengh) Or (ERROR_COM = True))
   order1 = Mid(Instring, 6, 2)  '结束码
   Call ErrMessage(order1)
     Text1.Text = Mid(Instring, 8, 4) * 0.099695  '取出数据位
End Sub
Private Sub Timer2_Timer()
tim = tim + 1
End Sub
Public Function ErrMessage(ByVal X As String)
 Select Case X
   Case "13"
     MsgBox "校验错误"
   Case "14"
     MsgBox "格式错误"
   Case "15"
     MsgBox "入口码错误"
   Case "18"
     MsgBox "帧长度错误"
   Case "A3"
     MsgBox "传送数据时因FCS错误引起终止"
   Case "A8"
     MsgBox "传送数据时因长度错误引起在终止"
 End Select
End Function
Function XORR(ByVal STRI As String) As String   '校验码的异或处理
Dim I, J, K As Integer
J = Len(STRI)
K = 0
For I = 1 To J
 K = Asc(Mid$(STRI, I, 1)) Xor K
Next I
fcdd$ = Hex$(K)
If Len(fcdd$) = 1 Then
 XORR = "0" & fcdd$
Else
 XORR = fcdd$
End If
End Function
Private Sub Timer3_Timer()
   outstring = "@" + "00" + "RD" + "0034"
   Time_out = tim
  '判断通讯错误
   Do
       ERROR_COM = True
     Else
       ERROR_COM = False
     End If
       DoEvents
     Text3.Text = Mid(Instring, 8, 4) * 0.099695  '取出数据位
End Sub
Private Sub Timer4_Timer()
   outstring = "@" + "00" + "RD" + "0038"
   Time_out = tim
  '判断通讯错误
   Do
       ERROR_COM = True
     Else
       ERROR_COM = False
     End If
       DoEvents
     Text5.Text = Mid(Instring, 8, 4) * 0.099695  '取出数据位
End Sub
Private Sub Timer5_Timer()
Text6.Text = Time
End Sub
1048
ZHANGYL1981
文章数:12
历史总积分:1048
发表于:2007/10/25 8:56:00
有高手吗!帮帮忙啊
2926
流客
文章数:794
历史总积分:2926
发表于:2007/10/25 20:39:00
Dim tim As Integer
Time_out = tim
没看到您给 tim赋值呀,
应该是Time_out =Timer吧
2926
流客
文章数:794
历史总积分:2926
发表于:2007/10/25 20:43:00
这种通讯方法,就是通讯成功了也不适合工程用,通讯速度太慢。
1048
ZHANGYL1981
文章数:12
历史总积分:1048
发表于:2007/10/26 12:32:00
tim 是秒的计数啊应该没什么问题啊
1332
wjun7610
文章数:138
历史总积分:1332
发表于:2007/10/26 19:51:00
你这种通讯方法存在问题,即使成功也不能达到很好的效果,你可以试试我的DLL不需要串口控件,我的欧姆龙PLC host Link通讯协议DLL支持VB、VC、Dephi等多种开发环境,稳定可靠,通用性强,联系QQ:157610979 Wjun7610◎yahoo.com.cn表情
1050
HaveGood
文章数:-11
年度积分:-729
历史总积分:1050
发表于:2007/11/16 23:04:00
此楼内容不符合板块规定,不予显示! 查看原帖内容>>
93.7997
