回帖:1个,阅读:1039次 [上一页] [1] [下一页]
现场问题
1005
caiyalong
文章数:1
历史总积分:1005
发表于:2007/10/6 18:10:00
the PG/PC interface that is being used is communicating right now. first close the conections that are still open and then reactivate the connection setup?各位老大谁能帮我解决这个问题?
1040
liangqinghua
文章数:6
历史总积分:1040
发表于:2007/10/6 20:30:00
PG/PC接口正在交换数据,先将连接断开,然后激活连接设置。
46.8003
