无线通信
回帖:0个,阅读:1712次 [上一页] [1] [下一页]
1090
satel
文章数:10
历史总积分:1090
发表于:2007/9/19 17:20:00
SATELLINE 3ASD EPIC PRO
为远距离传输定制的数传电台
SATELLINE-3ASd Epic Pro is an IP67 classified UHF radio modem with
a high power (10 W) transmitter. It is particularly well suited for outdoor use (land surveying, for instance) under varying weather conditions.
Due to the high transmitting power, connection distances of up to 80 kilometers can be covered.
According to the IP67 standard, the casing and connectors of the SATELLINE-3ASd Epic Pro are waterproof and secured against dust. The radio modem is equipped with a Liquid Crystal Display (LCD), used to indicate the current operating status (frequency, channel number, power level, voltage level, field strength), as well as for changing the setups of the radio modem.
The SATELLINE-3ASd Epic Pro radio modem is a special "Dual Band" version. The radio transceiver of the Dual Band version offers as an option two 2 MHz frequency bands, tuned at the factory with maximum separation of 12 MHz between the highest and the lowest frequency. The radio modem can be reprogrammed to operate at any channel within those two bands.
Frequency range   370 ... 470 MHz
Channel spacing 12.5 / 20 / 25 kHz
Communication mode Half-duplex
Carrier power   1, 5 or 10 W / 50 ohm
Sensitivity   -116 ... -110 dBm (BER < 10 E-3)
Adjacent channel selectivity > 60 dB /> 70 dB
Interface   RS-232
Interface connector Lemo compatible 8-pin, waterproof
Data speed of RS interface 300 - 38400 bps
Data speed of radio interface 19200 bps (25 kHz channel)
9600 bps (12.5 / 20 kHz channel)
Data formats Asynchronous data
Operating voltage   +11.8 ... + 30 Vdc
Power consumption 1.3 VA typical (receive)
30 VA typical (transmit)
0.05 VA typical
(when DTR is "0")
Temperature range -25°C ... +55°C
Antenna connector TNC, 50 ohm, female
Construction Aluminium enclosure
Size H * W * D 165 * 138 * 57 mm
Weight 1300 g
IP Classification IP67 (NEMA6)[/face][/color]
satelchina co.,ltd   MR. Johnny
31.2002
