回帖:0个,阅读:1357次 [上一页] [1] [下一页]
PLC414H系统故障描述
1105
paul791117
文章数:42
历史总积分:1105
发表于:2007/6/12 10:49:00
0号机架上的CPU 死机,所有的灯都闪,CPU重启无效,关掉电源再重启后恢复,但过几天又出现上述故障现象。此现象是2007年5月18日首次出现,到现在已多次发生,影响到我厂的安全生产,请各位帮忙解决。
以下是截取的6条诊断信息:
Module Information -CPU 414-4 H "Diagnostic Buffer" Tab
Settings:
 Time including CPU/Local time difference(0 h)
Event 104 of 120: Event ID 16# 7301
Loss of redundancy (2oo2) due to CPU failure
CPU affected:Standby CPU in rack 0
Event: Standby CPU : Change from redundant mode to error-search mode
Requested OB: CPU redundancy error OB (OB72)
Event 103 of 120: Event ID 16# 45E4
Error-search mode :trigger event: 43D8:Error-search mode : Hardware error detected due to other error
FC number :110
Moudle address: 1220
Event occured in the standby CPU in rack 0
Event 100  of 120: Event ID 16# 5371
Distributed I/Os: end of the synchronization with a DP master
Slot of the DP master:4 in rack 0
Number of distributed stations: 8
Event 84 of 120: Event ID 16# 7955
SYNC submodule error
occured in : Master CPU in rack 1, no relevance for USER : 01
Submodule affected: Upper SYNC submodule (IFM1F)
Requested OB : CPU redundancy error OB (OB72)
External error, Incoming event
Event 78 of 120: Event ID 16# 7855
SYNC submodule error eliminated
occured in : Master CPU in rack 1, no relevance for USER : bb
Submodule affected: Upper submodule (IFM1F)
Requested OB : redundancy error OB (OB72)
Event 106 of 120: Event ID 16# 6981
Interface error entering state
Interface ID : X1,MPI/DP
Event occurred in the standby CPU in rack 0
External error, Incoming enent
31.2002
