嵌入式系统
回帖:1个,阅读:1688次 [上一页] [1] [下一页]
1005
thomasdu
文章数:6
历史总积分:1005
发表于:2007/4/13 18:43:00
沉寂几个月的心血,终于告一段落,终于可以愉快地上网玩了,将来还请各位大大多多指导!
总结一下成果:
           使用了廉价ARM7芯片S3C44B0X和RTL8019网络芯片,没办法,成本控制啊!
           编写了BootLoader,写了uClinux的控制台驱动,移植成功网卡驱动,Yeah!
下一步工作:
           准备启动Telnet服务程序,去掉串口Console,就可以使用两个串口了。
Look:
Program    :    DuTao''s 44b0x BootLoader Ver 0.60
UART config:    115.2kbps,8Bit,NP,UART0
Flash ID   :    0x236d00bf
RTL8019 ID :    0x00007050
Initializing system... ...
1.Download code to SDRAM.
2.Copy data in SDRAM.
3.Run at specify address.
4.Start uClinux.
5.View Data.
6.Programe Flash.
Load image.rom...
Copy uClinux
Copy Romfs
Start uClinux
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.6.17-uc1[DT-Ver-1.2] (root@localhost.localdomain) (gcc version 3.4.0) #696 Wed Apr 4 22:36:59 CST 2007
CPU: Samsung-S3C44B0x [44b07700]
Machine: S3C44B0X Development Board
CPU0: D VIVT write-through cache
CPU0: cache: 512 bytes, associativity 1, 8 byte lines, 64 sets
Built 1 zonelists
Kernel command line: root=/dev/ram0 initrd=0x0c300000,1200k keepinitrd
PID hash table entries: 128 (order: 7, 512 bytes)
S3C44B0X Serial Console Driver By Tao.Du <ThomasDutao@HotMail.com>
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 30MB = 30MB total
Memory: 28060KB available (928K code, 163K data, 64K init)
Mount-cache hash table entries: 512
checking if image is initramfs...it isn''t (bad gzip magic numbers);
looks like an initrd, initrd_start=0xc300000, initrd_size=1228800
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
ttyS0 at I/O 0x1d00000 (irq = 3) is a Samsung S3C44B0 Internal UART
ttyS1 at I/O 0x1d04000 (irq = 2) is a Samsung S3C44B0 Internal UART
Samsung S3C44B0 Rtl8019as driver version 0.1 (2002-02-20) <hzh12@163.net>
Init RT8019 with 16 BIT modle
eth0: 12:34:56:78:90:ab
NetWinder Floating Point Emulator V0.97 (double precision)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
RAMDISK driver initialized: 2 RAM disks of 2048K size 1024 blocksize
loop: loaded (max 8 devices)
TCP bic registered
RAMDISK: romfs filesystem found at block 0
RAMDISK: Loading 997KiB [1 disk] into ram disk... done.
VFS: Mounted root (romfs filesystem) readonly.
Freeing init memory: 64K
console init ready.
Star run init process!
do_execve(...) @ fs/exec.c:01222 exec /sbin/init successfully !
do_execve(...) @ fs/exec.c:01222 exec /bin/sh successfully !
Shell invoked to run file: /etc/rc
Command: hostname Thomas.du
do_execve(...) @ fs/exec.c:01222 exec /bin/hostname successfully !
Command: /bin/expand /etc/ramfs.img /dev/ram1
do_execve(...) @ fs/exec.c:01222 exec /bin/expand successfully !
Command: mount -t proc proc /proc
Command: mount -t ramfs /dev/ram1 /var
Command: mkdir /var/config
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: cat /etc/motd
Welcome to
          ____ _  _
        /  __| ||_|
   _   _| |  | | _ ____  _   _  _  _
  | | | | |  | || |  _ \| | | |\ \/ /
  | |_| | |__| || | | | | |_| |/    \
  |  ___\____|_||_|_| |_|\____|\_/\_/
  |_|
For further information check:
http://www.uclinux.org/
   *  Last Step Completed By Dutao @ 200703  *
   *                 Yeah !                  *
Command: ifconfig lo 127.0.0.1
do_execve(...) @ fs/exec.c:01222 exec /bin/ifconfig successfully !
Command: route add -net 127.0.0.0 netmask 255.255.255.0 lo
do_execve(...) @ fs/exec.c:01222 exec /bin/route successfully !
Command: ifconfig eth0 192.168.1.123 netmask 255.255.255.0 up
enable_irq(24) unbalanced from 0c01fb60
Execution Finished, Exiting
Open file /dev/inet Error !
do_execve(...) @ fs/exec.c:01222 exec /bin/inetd successfully !
Sash command shell (version 1.1.1)
/> ping 192.168.1.1
do_execve(...) @ fs/exec.c:01222 exec /bin/ping successfully !
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=10.0 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.0 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.0 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.0 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.0 ms
--- 192.168.1.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.0/2.0/10.0 ms
/> cat /proc/cpuinfo
Processor       : Samsung-S3C44B0x rev 0 (v4l)
BogoMIPS        : 29.79
Features        : swp 26bit
CPU implementer : 0x44
CPU architecture: 4T
CPU variant     : 0x30
CPU part        : 0x770
CPU revision    : 0
Cache type      : write-through
Cache clean     : not required
Cache lockdown  : not supported
Cache format    : Unified
Cache size              : 512
Cache assoc             : 1
Cache line length       : 8
Cache sets              : 64
Hardware        : S3C44B0X Development Board
Revision        : 0000
Serial          : 0000000000000000
[此贴子已经被作者于2007-4-13 18:46:49编辑过]
------------ I Love uClinux ----------
1005
thomasdu
文章数:6
历史总积分:1005
发表于:2007/4/13 18:59:00
准备下班了,自沙了。
671.8852
