运动控制
回帖:223个,阅读:73763次 [上一页] [1] [2] [3] [4] [5] [6] [7] [8] [9] ... [23] [下一页]
1630
TQL-A
文章数:207
历史总积分:1630
发表于:2005/6/20 16:38:00
请教:伺服电机的结构及工作原理
   谢谢
1103
liang971808
文章数:21
历史总积分:1103
发表于:2005/6/21 9:14:00
交流伺服电机的工作原理
  伺服电机内部的转子是永磁铁,驱动器控制的U/V/W三相电形成电磁场,转子在此磁场的作用下转动,同时电机自带的编码器反馈信号给驱动器,驱动器根据反馈值与目标值进行比较,调整转子转动的角度。伺服电机的精度决定于编码器的精度(线数)。
4. 什么是伺服电机?有几种类型?工作特点是什么?
答:伺服电动机又称执行电动机,在自动控制系统中,用作执行元件,把所收到的电信号转换成电动机轴上的角位移或角速度输出。分为直流和交流伺服电动机两大类,其主要特点是,当信号电压为零时无自转现象,转速随着转矩的增加而匀速下降,
请问交流伺服电机和无刷直流伺服电机在功能上有什么区别?
答:交流伺服要好一些,因为是正弦波控制,转矩脉动小。直流伺服是梯形波。但直流伺服比较简单,便宜。
永磁交流伺服电动机
1630
TQL-A
文章数:207
历史总积分:1630
发表于:2005/6/21 20:46:00
请教2楼:伺服电机编码器为17位,定位精度能否达到360/131072度
         谢谢
2699
宝贝塌塌鼻
文章数:780
历史总积分:2699
发表于:2005/6/29 17:04:00
以下是引用TQL-A在2005-6-21 20:46:00的发言:
          谢谢
我也想知道哦
1010
qym1113
文章数:3
历史总积分:1010
发表于:2005/6/30 16:06:00
编码器的位数和定位精度的关系什么?谢谢
1241
sapphire
文章数:99
历史总积分:1241
发表于:2005/7/3 0:09:00
定位精度是指在一圈下的编码器脉冲数所对应的行程。
如果编码器为17位,即13万线,则一圈的电机旋转对应100mm的位置移动,定位精度为100mm/130000。
这是理论值,因为,机械系统的精度很难与电气控制系统来匹配。
1241
sapphire
文章数:99
历史总积分:1241
发表于:2005/7/3 0:13:00
Servomotors are available as AC or DC motors. Early servomotors were generally DC motors because the only type of control for large currents was through SCRs for many years. As transistors became capable of controlling larger currents and switching the large currents at higher frequencies, the AC servomotor became used more often. Early servomotors were specifically designed for servo amplifiers. Today a class of motors is designed for applica-tions that may use a servo amplifier or a variable-frequency controller, which means that a motor may be used in a servo system in one application, and used in a variable-frequency drive in another application. Some companies also call any closed-loop system that does not use a stepper motor a servo system, so it is possible for a simple AC induction motor that is connected to a velocity controller to be called a servomotor.
Some changes that must be made to any motor that is designed as a servomotor in-cludes the ability to operate at a range of speeds without overheating, the ability to operate at zero speed and retain sufficient torque to hold a load in position, and the ability to operate at very low speeds for long periods of time without overheating. Older-type motors have cooling fans that are connected directly to the motor shaft. When the motor runs at slow speed, the fan does not move enough air to cool the motor. Newer motors have a separate fan mounted so it will provide optimum cooling air. This fan is powered by a con-stant voltage source so that it will turn at maximum RPM at all times regardless of the speed of the servomotor. One of the most usable types of motors in servo systems is the permanent magnet (PM) type motor. The voltage for the field winding of the permanent magnet type motor can be AC voltage or DC voltage. The permanent magnet-type motor is similar to other PM type motors presented previously. Figure 11-83 shows a cutaway picture of a PM motor and Fig. 11-84 shows a cutaway diagram of a PM motor. From the picture and diagram you can see the housing, rotor and stator all look very similar to the previous type PM motors. The major difference with this type of motor is that it may have gear reduction to be able to move larger loads quickly from a stand still position. This type of PM motor also has an encoder or resolver built into the motor housing. This ensures that the device will accurately indicate the position or velocity of the motor shaft.
1241
sapphire
文章数:99
历史总积分:1241
发表于:2005/7/3 0:14:00
11.11.5.1 Brushless Servomotors The brushless servomotor is designed to operate without brushes. This means that the commutation that the brushes provided must now be provided electronically. Electronic commutation is provided by switching transistors on and off at appropriate times. Figure 11-85 shows three examples of the voltage and current waveforms that are sent to the brushless servomotor. Figure 11-86 shows an example of the three windings of the brushless servomotor. The main point about the brushless servomo-tor is that it can be powered by either ac voltage or dc voltage.
Figure 11-85 shows three types of voltage waveforms that can be used to power the brushless servomotor. Figure ll-85a shows a trapezoidal EMF (voltage) input and a square wave current input. Figure ll-85b shows a sinusoidal waveform for the input voltage and a square wave current waveform. Figure ll-85c shows a sinusoidal input waveform and a sinusoidal current waveform. The sinusoidal input and sinusoidal current waveform are the most popular voltage supplies for the brushless servomotor.
Figure 11-86 shows three sets of transistors that are similar to the transistors in the output stage of the variable-frequency drive. In Fig. ll-86a the transistors are connected to the three windings of the motor in a similar manner as in the variable-frequency drive. In Fig. 1 l-86b the diagram of the waveforms for the output of the transistors is shown as three separate sinusoidal waves. The waveforms for the control circuit for the base of each transis-tor are shown in Fig. ll-86c. Figure ll-86d shows the back EMF for the drive waveforms.
1241
sapphire
文章数:99
历史总积分:1241
贴出来挺麻烦的,有图片很多,关于伺服系统的原理,如果需要我发给大家吧!
请留下地址!
6385
karl 版主
文章数:1703
历史总积分:6385
发表于:2005/7/3 16:23:00
以下是引用sapphire在2005-7-3 0:14:00的发言:
请留下地址!
贴出来吧,加钻鼓励!
5609.9935
