串口通信
回帖:5个,阅读:11689次 [上一页] [1] [下一页]
916
wo_net_wo
文章数:5
历史总积分:916
发表于:2002/4/12 0:05:00
各位同行好:
   本人初入该网站,对该站的一些话题很感兴趣,对于WINDOWS的串行通讯,我认为采用异步
方式可能会更好,下面是一段用vc++ 写的通讯程序,本人曾用在多个项目中,供大家参考。
CComm::CComm()
CComm::~CComm()
void CComm::SetCommByteSize(BYTE bByteSize)
m_bByteSize=bByteSize;
void CComm::SetCommParity(BYTE bParity)
m_bParity=bParity;
void CComm::SetCommStopBits(BYTE bStopBit)
m_bStopBits=bStopBit;
BOOL CComm::OpenCommConnect(COMMINFO commInfo)
  if(m_osRead.hEvent==NULL){return FALSE;}
  COMMTIMEOUTS  CommTimeOuts ;
  char szPort[15],szTemp[64];
  wsprintf(szPort,"COM%d",commInfo.bPort);
  m_idComDev=CreateFile( szPort, GENERIC_READ | GENERIC_WRITE,
                 0,
                 NULL,
                 OPEN_EXISTING,
                 FILE_ATTRIBUTE_NORMAL |
                 FILE_FLAG_OVERLAPPED,
                 NULL );
  if(!m_idComDev )
  wsprintf(szTemp,"Open %s Fail",szPort);
  MessageBox(NULL,szTemp,"Ininital Com Error",MB_OK);
  return FALSE;
  if(SetupCommConnect(commInfo))
m_fConnected=true;
  CommTimeOuts.ReadIntervalTimeout = 0;
   CommTimeOuts.ReadTotalTimeoutMultiplier = 0 ;
   CommTimeOuts.ReadTotalTimeoutConstant = 200;
   CommTimeOuts.WriteTotalTimeoutMultiplier = 0;
CommTimeOuts.WriteTotalTimeoutConstant =50 ;
   SetCommTimeouts( m_idComDev, &CommTimeOuts ) ;
SetupComm(m_idComDev,256,256);// set the len of buffer for tansfer
PurgeComm(m_idComDev,PURGE_TXABORT | PURGE_RXABORT |
                        PURGE_TXCLEAR | PURGE_RXCLEAR ) ;
EscapeCommFunction( m_idComDev, SETDTR ) ;
return TRUE;
  else
m_fConnected=false;
CloseHandle(m_idComDev);
return FALSE;
BOOL CComm::SetupCommConnect(COMMINFO commInfo)
  BOOL       fRetVal ;
  DCB        dcb ;
  dcb.DCBlength = sizeof( DCB ) ;
  GetCommState(m_idComDev, &dcb ) ;
  dcb.BaudRate = commInfo.dwBaudRate;
  dcb.ByteSize = commInfo.bByteSize;
  dcb.Parity =commInfo.bParity;
  dcb.StopBits =commInfo.bStopBits ;
  fRetVal = SetCommState(m_idComDev,&dcb) ;
  return ( fRetVal ) ;
BOOL CComm::CloseConnect()
if(!m_fConnected)
return TRUE;
m_fConnected=false;
SetCommMask( m_idComDev, 0 ) ;
   PurgeComm( m_idComDev , PURGE_TXABORT | PURGE_RXABORT |
   EscapeCommFunction(m_idComDev, CLRDTR ) ;
   CloseHandle(m_osRead.hEvent);
   CloseHandle(m_osWrite.hEvent);
   CloseHandle( m_idComDev ) ;
   return TRUE;
int CComm::ReadFromComm(unsigned char* lpszRcvBuffer,int iMaxLen,DWORD& error )
  DWORD      dwLengthrd;
  DWORD      dwLength;
  if(m_idComDev==(HANDLE)-1)
    return 0;
   dwLength =iMaxLen;
   if(!waitonread)
if(!ReadFile( m_idComDev, lpszRcvBuffer, dwLength, &dwLengthrd, &m_osRead))
  if (GetLastError() != ERROR_IO_PENDING)
{ Sleep(1000);
 error=1;
return 0;}
  waitonread=true;
else
{   error=0;
return dwLengthrd;}
  if(waitonread)
 if(WaitForSingleObject(m_osRead.hEvent,500)!=WAIT_OBJECT_0)
     {   error=3;
 return 0;}
    if(!GetOverlappedResult( m_idComDev,&m_osRead, &dwLengthrd, FALSE ))
      return 0;
    waitonread=false;
  error=0;
  return ( dwLengthrd ) ;
int CComm::WriteToComm(char* lpszSendBuffer,DWORD  dwLength,DWORD& error)
  DWORD       dwBytesWritten ;
    return 0;
   if(!waitonwrite)
if(!WriteFile( m_idComDev, lpszSendBuffer, dwLength, &dwBytesWritten, &m_osWrite))
error=1;
Sleep(1000);
return 0;
  waitonwrite=true;
else
{   error=0;
return dwBytesWritten;}
  if(waitonwrite)
 if(WaitForSingleObject(m_osWrite.hEvent,500)!=WAIT_OBJECT_0)
     {   error=2 ;
 return 0;}
    if(!GetOverlappedResult( m_idComDev,&m_osWrite, &dwBytesWritten, FALSE ))
    return 0;
  waitonwrite=false;
   error=0;
  return (dwBytesWritten ) ;
HANDLE CComm::GetComDev()
return m_idComDev;
BOOL CComm::GetConnected()
return m_fConnected;
void CComm::SetBaudRate(DWORD dwBaudRate)
m_dwBaudRate=dwBaudRate;
void CComm::SetCommPort(BYTE bPort)
m_bPort=bPort;
BOOL CComm::ChangeBaudRate(DWORD dwBaudRate)
  BOOL       fRetVal;
  DCB        dcb;
  dcb.BaudRate = m_dwBaudRate;
BOOL CComm::ChangeCommByteSize(BYTE bByteSize)
   BOOL       fRetVal;
   DCB        dcb;
dcb.ByteSize = m_bByteSize;
   return ( fRetVal );
BOOL CComm::ChangeCommParity(BYTE bParity)
BOOL       fRetVal;
   DCB        dcb;
   m_bParity=bParity;
dcb.Parity = m_bParity;
   return ( fRetVal );
BOOL CComm::ChangeCommStopBits(BYTE bStopBit)
BOOL       fRetVal;
   DCB        dcb;
dcb.StopBits = m_bStopBits;
   return ( fRetVal );
void CComm::purge()
PurgeComm(m_idComDev,PURGE_RXCLEAR|PURGE_TXCLEAR);
void CComm::InitParam()
m_fConnected=false;
916
wo_net_wo
文章数:5
历史总积分:916
发表于:2002/4/12 0:15:00
Sorry!
void XhComm::InitCom()
m_idComDev=0;
m_fConnected=false;
   memset( &m_osWrite, 0, sizeof( OVERLAPPED ) ) ;
memset( &m_osRead, 0, sizeof( OVERLAPPED ) ) ;
waitonread=false;
   waitonwrite=false;
m_osRead.hEvent=CreateEvent(NULL,TRUE, FALSE,NULL);
m_osWrite.hEvent=CreateEvent(NULL,TRUE,FALSE,NULL);
if(m_osWrite.hEvent==NULL) {CloseHandle(m_osRead.hEvent);}
969
littleke
文章数:21
历史总积分:969
发表于:2003/1/13 16:32:00
Re:WINDOWS下的异步串行通讯
ok,请问用vb怎么写?
1077
kueni2000
文章数:15
历史总积分:1077
发表于:2005/10/10 10:22:00
ok! 但是我只会VB
1072
tiasky
文章数:23
历史总积分:1072
发表于:2005/10/16 8:28:00
485通信编程的难点在于完整正确的数据包的提取,一般有二种方法:
  1: 数据包前加同步帧,包长度信息,校验码.
  2: 通过接收数据的时间判断,如>50ms未有新数据,判断一个包接收结束. 欢迎到我网站下载 www.tiasky.com
  串口调试工具:SPCfgTest.zip 大小为 252 KB
   调整字节串接收时间(10mS~200mS),可将一般串口调试工具收不全的数据全收全;或不应断开收的数据收全、收完整。
中央解决"三农",又迅解决"三太":太贵、太难、太复杂。
http://www.autoyx.com/
17628
ahljj
文章数:3386
历史总积分:17628
发表于:2013/11/25 16:32:41
学习一下。。。
5406.2869
